Cisco Connections
BHconsultants88
Hi guys, hope someone can help with this. I'm sure its very simple but the kit is in a remote site and I want to make sure I have it right before calling the onsite guy there tomorrow
We have:
  • Modem connected to Cisco 800 WAN port configured with /30 WAN IP and /24 LAN IP (10.88.40.2)
  • Cisco 1941 with GE-0/0 configured with 10.88.40.3. This is connected to LAN port of Cisco 800
The reason there are 2 x Cisco's is rather ridiculous. The ISP is unable to offer any NAT configuration on their Cisco 800 which is why we have had to introduce our own NAT friendly Cisco 1900 on the inside.
  1. Can somebody clarify the physical connection required between each router? Is it 800 LAN to 1900 LAN, or 800 LAN to 1900 WAN?
  2. If LAN to LAN, would GE-0/1 on the 1900 need to be configured with another IP address for the remote site LAN to connect into?
Would appreciate your thoughts :-)
11 Replies 11
Richard Burts
I find it surprising that the ISP is unable to offer any NAT configuration on their 800 router. But if that is the case then using your own 1941 is an appropriate solution. On the 800 the connection would be on the inside interface and so is classified as LAN. On the 1941 they do not use classifications in quite the same way. But gig0/0 is the outbound interface and so in logical terms it would be WAN and gig0/1 is the inbound interface and so in logical terms it would be LAN. gig0/0 has its IP address and would need to be configured as the nat outside interface. gig0/1 would need an IP address in a different subnet, would need to be configured as nat inside and this would be where users etc are connected.
Rick
Rick
Hi Richard, thanks for your response. I've finally got around to doing this so hopefully it will work without major glitches. Unfortunately, it's something to do with their core routers but I've never seen this before. Regardless, this is what I have so far:
Cisco 800 has LAN address of 10.88.24.1 /24
  • interface GigabitEthernet0/0
    description Internet
    ip address 10.88.24.2 255.255.255.0
    no ip redirects
    no ip proxy-arp
    ip nat outside
    ip virtual-reassembly in
    shutdown
    duplex auto
    speed auto
    no cdp enable
    interface GigabitEthernet0/1
    description LAN Segment
    ip address 62.14.44.108 255.255.255.0 secondary
    no ip redirects
    no ip proxy-arp
    ip nat inside
    shutdown
    duplex auto
    speed auto
    no cdp enable
ip nat pool BOATCLUB 10.88.24.20 10.88.24.254 netmask 255.255.255.0
ip nat inside source list 1 pool BOATCLUB
ip nat inside source static 62.14.44.47 10.88.24.15
ip route 172.18.0.0 255.255.0.0 62.14.44.254
How does that look to you?
There are several things in this to address:
- both interfaces are currently shutdown. That means they will not transmit or receive anything. You need to no shutdown on both interfaces.
- Gi0/1 has a secondary address but no primary address. Do you intend to have two IP addresses associated with this interface?
- the IP address assigned to Gi0/1 is a public IP address. It is not clear why you have a public IP here. Since you will be doing address translation I would have expected a private address.
- you have a pretty large pool of addresses for translation and they are in the subnet used by the ISP. Is this intentional? Does the ISP expect to receive traffic from that many addresses in this subnet?
Rick
Rick
Thanks for coming back
- I've put them in shutdown state for now, will enable them tomorrow morning
- That's a typo, GE-0/0 does not have a secondary address
This is the information I have received regarding the public IP, let's assume the 62 range is correct...
Proxy-server performs NAT for 172.18.0.0/24 network. This private network translates to real IP  62.14.44.32
So, the local network is 62.14.44.0 /24. The Cisco 1900 sees this network through Interface Gi0/1, which has an IP address from this it 62.14.44.0 /24 network
So does that mean I should be Natting the 172.18.0.0 /24 range?
I am glad that you are aware of the shutdown state and that it is intentional. I can only comment on what I see in the config since I have no information about your environment or about your plans.
I understand that the IP address is really primary and not secondary. I am still not understanding what is the intention for the LAN connected to Gi0/1. Are the devices connected in the LAN to be in network 172.18.0.0/24 and then to be translated to 62.148.14.32? Or are the connected devices in network 62.148.14.0? And if so then where is 172.18.0.0?
Rick
Rick
No worries, I do appreciate your feedback.
Yes you are right. The actual LAN is 172.18.0.0 /24 but is Natted by the local proxy to 62.148.14.0 /24
All PC's connected to Gi-0/1 will require Internet access via the Cisco 800's LAN (10.48.124.0 /24) hence the Natting on the Cisco 1900
Hopefully that makes sense :)
Thanks for the clarification. If the actual LAN is 172.18.0.0/24 then I would expect that the interface IP on the 1900 would be an address in that subnet. You would then configure the 1900 to NAT those addresses to the 62.148.14.0.
Rick
Rick
Thanks Richard,
I'm having a problem at the moment in that I'm not learning routes for 10.88.24.0 /24
Would I need to add a route on the Cisco 1900 directing all traffic to Cisco 800 (10.88.24.1)?
Here are my current routes:
C 10.88.24.0/24 is directly connected, GigabitEthernet0/0
L 10.88.24.2/32 is directly connected, GigabitEthernet0/0
L 10.88.24.12/32 is directly connected, GigabitEthernet0/0
62.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 62.148.14.0/24 is directly connected, GigabitEthernet0/1
L 62.148.14.208/32 is directly connected, GigabitEthernet0/1
S 172.18.0.0/16 [1/0] via 62.148.14.254
I am not clear what you are saying here. You say that you are not learning routes for 10.88.24.0. But the route table that you show clearly has an entry for 10.88.24.0. Is there an issue about 10.88.24.0?
You certainly do need a default route on the 1900 with the IP of the 800 as the next hop.
Rick
Rick
Hi Richard, thanks for that. I have a similar scenario again whereby the Cisco 800 is unable to do NAT. Do you think this would do the trick?
Cisco 800 interface: 10.88.20.2
description WAN
ip address 10.88.20.1 255.255.255.0
no ip redirects
no ip proxy-arp
duplex auto
speed auto
no cdp enable
ip address 172.16.24.133 255.255.255.252 secondary
ip address 192.168.28.1 255.255.252.0
no ip redirects
no ip proxy-arp
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool BOWLA 10.88.20.60 10.88.20.200 netmask 255.255.255.0
ip nat inside source list 10 pool BOWLA
ip nat inside source static 192.168.188.12 10.88.20.11
ip nat inside source static 192.168.188.13 10.88.20.12
ip route 0.0.0.0 0.0.0.0 10.88.20.2
ip route 10.58.104.0 255.255.255.0 10.88.20.50
ip route 192.168.188.0 255.255.252.0 GigabitEthernet0/0 10.88.20.50
You need to add ip nat outside to interface Gig0/0
Rick
Rick
