syslogging
mialbert
Level 3
Level 3
Am wanting to know if it is possible, from a single isr or asa, to have isr or asa syslogging data sent to more than one collector(two specifically)
Julio E. Moisa
Please correct me if I am wrong, do you want to send logs from an ISR and ASA to a syslog server, you should execute the following command lines:
on ISR:
logging <IP of the syslog server 1>
logging <IP of the syslog server 2>
on ASA
logging host <interface where the server is known> <ip of the syslog server 1>
logging host <interface where the server is known> <ip of the syslog server 2>
I hope it is useful.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
on ISR:
on ASA
Yes.  What i am saying is i have one isr(for instance) and i am wanting to send syslog output from that one isr to two differenct syslog servers.  I believe what you stated above will address that.  Thank you
You are welcome 🙂
Yep that configuration will help you.
Thanks and have a great day.
