Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco csr1000v
Ruslan Silyayev
Hi. We have Cisco csr1000 virtual  router.
Here is sh ver:
CSR1000virtual#sh ver
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M),
Version 15.3(2)S2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 14-Aug-13 11:21 by mcpre
IOS XE Version: 03.09.02.S
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
CSR1000virtual uptime is 2 days, 20 hours, 31 minutes
Uptime for this control processor is 2 days, 20 hours, 32 minutes
System returned to ROM by reload
System image file is "bootflash:csr1000v-packages-adventerprisek9.03.09.02.S.153-2.S2"
Last reload reason: Reload Command
cisco CSR1000V (VXE) processor with 1141147K/6147K bytes of memory.
Processor board ID 9BLOBULI27O
2 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7774207K bytes of virtual hard disk at bootflash:.
We want to issue following commands:
radius-server vsa send accounting
radius-server vsa send authentication.
After issuing this sommands we can't see them in running config.
What can be the problem?
Hello Ruslan,
From the output we can see both commands are enabled by default, that's the reason you don't see it in a running config via regular "show running-config" command.
Starting 15.3(1)S onwards both commands are enabled by default.
Best regards,
Dmitry Skotnikov
-- Best regards, Dmitry Skotnikov
Hello Ruslan,
Would you be so kind to capture the following output:
# show run all | i vsa
Thank you
Best regards,
Dmitry Skotnikov
sh run all | include vs
device-sensor notify new-tlvs
radius-server vsa send cisco-nas-port
Hello Ruslan,
Best regards,
Dmitry Skotnikov
Thanks !
