CISCO SWITCH PART NUMBERS
mshirley551
Community Member
Could anyone please help...
On a Cisco switch part number like below you get a different letter at the end.  eg. -E, -S, -L etc
Does anyone know what the different letters mean?
WS-C2960-24PC-S
These letters tell you which Feature set is running on the switch. If you have a WS-C2960-24PC-S it's running the LAN Lite software, and the WS-C2960-24-PC-L is running the LAN Base software with more features.
You can find this info in the Data-Sheets of the particular product:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd806b0bd8.html
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Cheers, thanks for info
Seb Rupik
According to:
http://www.cisco.com/en/US/products/ps6406/prod_models_comparison.html
...'S' and 'L' denote feature set. Not sure about 'E' though?
johnlloyd_13
Level 11
Level 11
hi mark,
to my knowledge, the last letter depicts the IOS used by switch platform.
for your case, i believe you're running a standard image (hence for the 'S').
an 'E' is for enhanced image.
