Cisco CUBE connection to Skype via SIP
dwaters
Community Member
We have a Cisco 2801 running “c2801-ipvoice_ivs-mz.151-3.T2.bin”
We are trying to register to the Skype service using a Cisco CUBE, however so far no luck.
One question I do have is with regards to how NAT plays a part in this process? Do ports need to be opened inbound?
I can ping sip.skype.com fine.
Any suggestions would be great; two show commands below:
CUBE#show sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
9905100XXXXXXX                   -1         141         no
CUBE#
CUBE#show run | begin sip-ua
sip-ua
credentials username 9905100XXXXXXX password 7 XXXXXXXXXXXX realm sip.skype.com
authentication username 9905100XXXXXX password 7 XXXXXXXXXXX realm sip.skype.com
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server dns:sip.skype.com expires 3600 port 5060 transport udp unsolicited
registrar dns:sip.skype.com expires 3600
sip-server dns:sip.skype.com
connection-reuse
host-registrar
handle-replaces
Debugs are available upon request.
Thank you in advanced, Daniel.
Daniele Giordano
Level 11
Level 11
Try the command "debug ccsip messages" and post the output.
In working scenario, your cube should send a SIP REGISTER without authentication and get a 401 Unauthorized message.
After this the cube should send a SIP REGISTER with authentication.
If the REGISTER contains your local ip address, so Skype doesn't know how to respond.
In this case we will observ only REGISTER messages without answer.
We will check the top VIA header and the CONTACT header.
After this we can think to a NAT problem.
Regards.
6 Replies 6
Daniele Giordano
Level 11
Level 11
Regards.
Hi Daniele,
The "debug ccsip messages" is displayed below:
*Jan 20 11:46:19.556: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.skype.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.16.22:5060;branch=z9hG4bK285E1C
From: <>990510001XXXXXX@sip.skype.com>;tag=9A74C74-1EC1
To: <>990510001XXXXX@sip.skype.com>
Date: Fri, 20 Jan 2012 11:46:19 GMT
Call-ID: 86CA96C-411A11E1-8002CBD5-9140B2F5
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1327059979
CSeq: 647 REGISTER
Contact: <990510001XXXXX>
Expires:  3600
Supported: path
Content-Length: 0
Looks like you were stop on! Thank You very much.
Contact: <990510001XXXXX> answers all the questions I think. It’s a NAT problem. I'll setup some new static NAT and see where we go from there.
In my previous experience Static NAT wasn’t required, however in this scenario it looks essential.
Is the NAT process performed from your 2801 CUBE or do you use an external router?
You can use "debug ip nat sip" to check the NAT ALG function of cisco router.
The "ip nat service sip udp port 5060" should be enabled to default and should adjust REGISTER fileds that contain private ip addresses.
You can also use the "bind" command to use a specific interface for SIP signal:
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
Regards.
dwaters
Community Member
It turned out to be a NAT problem.
*Jan 20 13:58:44.664: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.1.16.22:5060;branch=z9hG4bK2A7170
From: <>99051000XXXXXX@sip.skype.com>;tag=A218DC4-159F
To: <>99051000XXXXX@sip.skype.com>
Date: Fri, 20 Jan 2012 13:58:44 GMT
Max-Forwards: 70
Timestamp: 1327067924
CSeq: 681 REGISTER
Contact: <9905100XXXXX>
Expires:  3600
Supported: path
Content-Length: 0
*Jan 20 13:58:44.712: //678/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
From: <>99051000XXXXX@sip.skype.com>;tag=A218DC4-159F
To: <>990510001XXXXX@sip.skype.com>;tag=44da78c1-c905628-0-fb5ae6a5-0
CSeq: 681 REGISTER
Contact: <990510001XXXX>;expires=300
Expires: 300
Content-Length: 0
Thank You again Daniele!
Daniel.
Having the same problems. How did you solve it? Thanks in advance.
