After setting the source port and destination port on the switch with the monitor session 1 command,
After "show interface", the number of output packets on the destination port, and the output & input packets on the source port are too different.
LI_5#sh monitor
Session 1
Type : Local Session
Source Ports :
Both: Gi1/1/4
Destination Ports :
Both: Gi1/1/1
LI_5# sh int g1/1/4
633637 packets input, 368561242 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
62 packets output, 266608 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
LI_5#sh int Gi1/1/1
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
55 packets output, 4465 bytes, 0 underruns
