Switch C9500-16X
gnpereira
Hello there,
It is possible to have one or more switches with the same Base Ethernet MAC Addres and Device-ID. Is there any way to change this information?
SWITCH 01
______________________________________
Base Ethernet MAC Address : 00:01:02:02:aa:bb
Motherboard Assembly Number : 73-18709-01
Motherboard Serial Number : FJZ245200N4
Model Revision Number : E0
Motherboard Revision Number : C0
Model Number : C9500-16X
System Serial Number : FJC24521FKY
SWITCH 02
_________________________________________
Motherboard Serial Number          : FJZ25020WC8
System Serial Number               : FJC250418ZP
These switches were purchased together. The problem I'm having is that Switch 01 has been installed and is working normally. Now when I'm trying to put Switch 02 on the network, switch 01 goes offline. I can't get the two to work together.
regards,
Gabriel
balaji.bandi
Looks for me BUG : (recently we seen same issue one of the thread)
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx58338
BB
 mac address could be a problem but it is not possible both have the same mac. When you say it goes off line means what exactly?
Are you adding the correct IP address for both. IP could also be a problem.
balaji.bandi
BB
gnpereira
Thank you very much @balaji.bandi . I will test Workaround.
Much appreciated for the help.
