Cisco Energywise
Steven Williams
Level 4
Level 4
I am having some issues finding the specific information about EnergyWise that I am after.
Does energywise shut down the port? So If I have a energywise schedule on a port that does not have a PoE device will that port be effected?
I have a few PoE devices that are programmed on a energywise schedule (on the port of the device) but the devices do not follow the energywise schedule, they never shutdown.
When a device shuts down because of energywise, how do I force that device back online before the schedule defines?
Steven Williams
Level 4
Level 4
Do I have this in the correct forum?
dverasteguin
i think you would have to set an energy level of 10 into that port so that the device can be turned back on
