04-20-2015 12:46 AM - edited 03-07-2019 11:38 PM
Hi Expertise,
I was trying to firmware update to Cisco 3750 stack switches.
I can copy to Flash1: of Switch 1 and successful.
However trying to copy to Flash2:, facing one the issue flash is full. When I check dir flash2 , find out one file 23052009.cfg
Is it safe to delete???
04-20-2015 02:37 AM
this is a configuration file.
someday, you copied the config file to flash
you have switch backups on an external fodler? tftp server?
You can also delete the following files:
- config.txt.backp
-private-config.text.backup.
but the solution is not that ... because the flash is short (now you have 2MB free and normal ISO need 11MB)... you have to delete the original ISO (c3750-ipservicesk8-mz.122-55.SE5) !
for delete:
delete /force /recursive flash2:c3750-ipservicesk8-mz.122-55.SE5
04-20-2015 06:50 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I agree with Tiago, i.e. that your principle problem is you need to remove the existing IOS image to free sufficient space for the replacement image. BTW, Tiago has a typo in the name of the existing directory.
Normally, you don't need to worry about tens of KB for some config files, but it appears you have a 3750 with only 16 MB flash. For those, with later IOS images, flash space can be very tight.
