Cisco 'GLC-T' is EOL the replacement is Cisco ‘GLC-TE’ but I can’t find the CLEI P/N Part Number?
kiyo
The Cisco copper SFP GLC-T has been EOL and the replacement is the Cisco SFP  ‘GLC-TE’ but I can’t find the CLEI P/N or Part Number anywhere on the Cisco sites. Can anyone tell me if they have used the 'GLC-TE' on a Cisco 3850 and Cisco 2960X? Can tell me what is the Part Number so that I can make sure I order the correct copper SFP?
cesarfer
Compatibility matrix of GLC-TE found attached.
The part id is GLC-TE=
Cesar Fernandez J
cesarfer
Cesar Fernandez J
Thank you Cesar :) This information was helpful.
