Cisco GLC-T replacement SFP
vladimir
Hi All,
We know that Cisco usualy OEM SFPs from Finisar and other brands. But can anybody tell which one of those SFPs is the correct replacement for Cisco GLC-T (or if all of them work):
     Finisar's FCLF-8520-3 or FCLF-8521-3
It seems like the difference between Finisar's 8520-3 & 8521-3 models are in RX_LOS pin operations:
http://www.finisar.com/sites/default/files/pdf/ZEBIYYxugGDBFCLF-8520-3_FCLF-8521-3_Spec_RevB[1].pdf
but it is unclear which one of them is the closest to GLC-T.
It looks like the same is true for Avago who has:
     Avago ABCU-5700RZ or ABCU-5710RZ
If you have an experience with any other 1000BASE-T SFPs that will work with Cisco routers please let us know.
Thanks.
0 Replies 0
