03-07-2022 08:24 AM
I was wondering if anyone could tell me whether or not the Cisco IE-1000 series switch supports configuration via CLI. So far I have been unable to find supporting information that demonstrates that this is possible. Can someone confirm?
Additionally, is it possible to change (or spoof) the MAC address for this device? I need to change the MAC on the SFP ports.
Thank you,
03-07-2022 08:32 AM - edited 03-07-2022 08:33 AM
User access to the switch through Telnet/SSH/DM can be controlled by TACACS+/RADIUS Authentication/Authorization.
it has ssh connection, for the SLA, not sure what MAc address you like to change ?
03-07-2022 08:48 AM
Thanks for the prompt response, balaji. So, I tried to ssh into the device after I completed the express config., but it doesn't appear to allow me. Also, I want to change the MAC address on the uplink interfaces, the 2x SFP ports. These two ports will be connected to two different systems that has switchport port-security enabled on them. I will not be present during the install, so disabling the port-security isn't an option atm, which is why I need to spoof the address to match an already approved mac address. Do you know if this is possible?
03-07-2022 08:57 AM
need to check the latest code for SSH to work :
https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie1000/release_notes/b_ie1k_1-7rn.html
