Cisco Interface Interpretation
Hello Experts
Can someone please take a look at the output of our interface and let me know how to determine the following over one hour:
Average bps
Min/Max Average bps
Min/Max Average Percent Utilization
Total Bytes Transferred
Average Packets per second
Total Packets Transferred
GigabitEthernet0/0 is up, line protocol is up
  Hardware is PQ3_TSEC, address is 7c69.f6f5.c670 (bia 7c69.f6f5.c670)
  Description: ** IP Connect Ethernet Flex ONEA915865 CSAC525324 ICUK711776 VPNN600200 **
  Internet address is 192.168.200.126/30
  MTU 1500 bytes, BW 20000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 2/255
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 04:36:23
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  30 second input rate 215000 bits/sec, 68 packets/sec
  30 second output rate 123000 bits/sec, 68 packets/sec
     1631166 packets input, 1568141970 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     1216265 packets output, 169362266 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Really appreciate your help
Cheers
Richard Burts
From one output it is not possible to get answers to these questions. If you get one output, wait an hour, and then get another output then some of your questions could be answered (total bytes and total packets). And from those figures you could calculate the average bps and average packets per second. The only way to get the values for min/max/average would be to take frequent ouputs and the accuracy of these answers would depend on how frequently you got the outputs.
Rick
Rick
Thanks Richard.
