Cisco ios upgaradation sup 2
ikbalc
I am facing issue while converting Cat IOS to native IOS in WS-X6K-SUP2-2GE. Chassis is 7606.
In conversion procedure, we have to take this SUP in LAN (for ping TFTP Server). But Ethernet port is not in SUP.
Can I do this conversion through consol only?
Can I connect SUP with TFTP server (without Ethernet Port)
Ikbal C
Jon Marshall
ikbalc@hcl.in
Ikbal C
Ikbal
You could use xmodem from your laptop/PC to copy the IOS onto the SUP but be aware that it is not a quick process.
Jon
Hi Jon,
Thanks for your suggestion.I already have tried Xmodem but it was not successfull.Could you please share the procedure for Xmodem so that i can cross check again.
Ikbal C
ikbalc@hcl.in
Hi Jon,
Ikbal C
Ikbal
Try this link -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/6.x/configuration/guide/images.html#wp1020467
Jon
Hi Jon,
I have tried Xmodem but i get the error like "error limit exceeded" on hyperterminal after some time.Any idea on this.
Ikbal
