Cisco IOS XE 17.6.4 not supported VRF features
ariffin_79
Dear Community Support,
I have attempt to configure vrf and ip vrf into cisco switch 9300 series. As per result i receive following notification:-
SWT812P.KUA.A(config)#ip vrf VRF_SERVER
% Feature is not supported
SWT812P.KUA.A(config)#vrf definition ?
Mgmt-vrf VRF Name
WORD VRF name
SWT812P.KUA.A(config)#vrf definition VRF_SERVER
I read into Cisco IOS XE  firmware17.x.x.x  release note and found one of unsupported feature is VRF. Can anyone help me. Do I need to open TAC case?.
Unsupported Features
  • Cisco TrustSec Network Device Admission Control (NDAC) on Uplinks
  • Converged Access for Branch Deployments
  • IPsec VPN
  • Performance Monitoring (PerfMon)
  • Virtual Routing and Forwarding (VRF)-Aware web authentication
Mohd Ariffin Zakaria
@rhallinan7387 mention correct point,
check the license in SW.
thanks
MHM
rhallinan7387
VRFs are certainly supported on the Catalyst 9300s - but you need the advantage license. I believe you get this error because you have the essentials license. Check:
sh run | inc license boot level
Reference this table here for features at different levels:
Cisco DNA Software Subscription feature matrix
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-swit-ser-cte-en.html
Dear rhallinan,
Many thanks for your advise. Could I download from cisco site or advantage license need to be purchase.
Mohd Ariffin
balaji.bandi
For VRF you need a network Advantage License.
you can use the right to use for testing : (once enable you to need to reload the device to take effect)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/sys_mgmt/b_166_sys_mgmt_9300_cg/b_166_sys_mgmt_9300_cg_chapter_011.html
BB
