CISCO ISE - Help with Radius Auth : Max session failed, but no session really in use ??? + AD Group different rights
Charly
We use Cisco ISE v2.3.0.298 Patch.3. / ISE-VM-K9 With 2 WLC 2504
Some users complain about not bein able to connect...
In the Live logs, we can see that the message says :22089 New user session not permitted. Max sessions user limit has been reached
We configured ISE to 1 connexion only, but in fact, no other session is present in the logs... ???
At the end, it says : 15039 Rejected per authorization profile
But username is not already in use...
Let's note that we have been sollicited on this issue after a ISE VM moved from one ESX to another... Can that be the problem ?
Is that a known Bug ?
Another think :
Our VIP population can have 2 or more Enpoints to connect at the same time on this WIFI.
We want only users from AD_VIP Activ dir group to use more than 1 Enpoint at the same time.
So I created a new User-Identity-Group named "Employee-MultiEndpoints", and mached the AD_VIP  Active-Directory Group in External-ID-Sources...
Then, I don't know how to correlate both groups... Am I going the wrong way ?
Thank you for your help !
Charly.
mohammed01701
Hi!
Are you sure you are not only allowing on session at time, there is setting that you can allow unlimited sessions see the Link:
https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-22/204463-Configure-Maximum-Concurrent-User-Sessio.html
/Mohammed
PedroDias1994
Have you found any solution for this?
Thanks.
