Cisco ISR 891 - Missing SDM?
iscs-mark
I have a Cisco 891 and I although I may never use it, I want to install and at least check out the SDM. When I go to http://router/ all I get is:
Cisco Systems
Accessing Cisco 891 "SR891"
Show diagnostic log - display the diagnostic log.
Monitor the router - HTML access to the command line interface at level 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
Connectivity test - ping the nameserver.
Show tech-support - display information commonly needed by tech support.
Extended Ping - Send extended ping commands.
QoS Device Manager - Configure and monitor QoS through the web interface.
I did do a search on cisco.com and see that the software I am running on the 891 supports SDM...how do I get to it? Or is there something else I am missing?
5 Replies 5
cadet alain
So there is no SDM on the 891. Is there any web interface at all?
It seems the doc I referenced before is a little bit outdated.
I did a search on Cisco feature navigator and it is supported since IOS 15.1(1)T
Regards.
Alain.
I saw that as well. The question is....how do I get to it? Everything I have read you are supposed to go to
http://www.cisco.com/pcgi-bin/tablebuild.pl/sdm to download the SDM....but that link does not work.
The SDM can be downloaded from the Cisco FTP site here:
ftp://ftp.cisco.com/pub/web/sdm/SDM-V25.zip
However, it is most probably required for you to log in using your CCO credentials. Accessing the FTP server anonymously may not permit you to download that file.
However, I kind of doubt that the SDM will be able to support your router. It has not been maintained for over 2 years and it needs a pretty old Java to be even able to run. I would personally suggest downloading and trying the Cisco Configuration Professional (CCP). You should be able to download the CCP here:
http://www.cisco.com/cisco/software/release.html?mdfid=281795035&softwareid=282159854&release=2.5&rellifecycle=&relind=AVAILABLE&reltype=latest
Best regards,
Peter
