Cisco ISR4000 series router and Licenses
fsebera
Level 4
Level 4
We have several ISR4351 routers and want to determine if the correct THROUGHPUT license has been applied. On bootup, the router spits out the log statement:
CMLIB-6-THROUGHPUT_VALUE:  R0/0: cmand:  Throughput license found, throughput set to 200000 kbps
The cli command -- show license all -- shows
feature: throughput
License Type:  Permanent
License state: Active, Not in use.
The marketing documentation state the Cisco ISR4351 router supports up to 400,000 Mbps throughput.
Does ANYONE have know or have documentation on the details of how to verify what licenses are active and usable based on the output of the cli commands?
Thank you kindly
Frank
Philip D'Ath
Use this command:
show platform hardware throughput level
