Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco LAG interfaces monitoring via snmp
hatterfix
Good day.
How can I check LAG interfaces status changing via snmp ? What type of oids I can use for
1) checking joining / unjoining status of interfaces in LAG
2) checking time after last joining.
3) checking LAG mode on interface (lacp/pagp)
4) checking global port-channel mode
e.t.c.
Reza Sharifi
You can monitor the physical interfaces and also Portchannels, so the software can send you alerts if they go down but not sure if you can monitor join and release or check timers. You may want to talk to your management software provider.
