Cisco LMS 4.2.3 is not generating protocol flap/down alarms.
tribhuwan07
Dears Espert,
We are using CISCO LMS 4.2.3 in our network in India, we are facing a issue regarding  alarm generation for a protocol flap/down, especially when BGP / OSPF neighbourship got flapped.
These flapping will result in the data service degradation , by which we came to know that some protocol flap may occurred at router end & then we go for the manual check by login into the router.
After escalating the same to cisco we came to know that it is a bug of Cisco LMS.
So, Does anybody among you is using any other method/technique to view the protocol down alarms automatically for cisco routers.
If yes , Please share the same.
Thanks & Regards
Tribhuwan Singh Danu
+91-8939671048
Leo Laohoo
Duplicate posts #1.
