Cisco LocalDirector
dappel
I am doing some switchport tuning using spanning-tree bpdu guard and loop guard.
Is the Cisco LocalDirector considered a switch where I would need to use loop guard? or would I need to configure the switchport with bpdu-guad?
hadbou
Level 5
Level 5
You have to find out which one is best for your network. Below is link to Provide with sample config and Reference documents and design guides
http://www.cisco.com/en/US/products/hw/contnetw/ps1894/products_installation_guide_book09186a008007e98e.html
http://www.qorbit.net/documents/cisco-local-director-abstract.htm
