Cisco Managed Switches for Ethernet/IP & Modbus TCP/IP protocols in a Ring Topology Ethernet Network
jose76
What are the equivalent Cisco Switches for the Stratix 5700 Switches?
With the Cisco Managed Switches (Layer 2), Ethernet Protocols (Modbus TCP/IP & Ethernet/IP) can be in the same network and in a ring topology without problems?
Please, refer to the attached drawing.
Jose
jose76
Cisco IE-2000 is an equivalent.
and it ensures some SFP and SSH management consistencies if you already have Cisco.
If you don't use a tight integration with Stratix and Allen Bradley it may be a good idea to stick with Cisco.
AB has a GUI and tight Integration with AB software.
Most locations that we have don't use the integration to AB software.
