cable-diagnostics tdr - Not Completed
hi.sadiki
Hello Guys,
We are facing latencies on our LAN. we have a  WS-C3750X-48PF-S switch with poe and phones in it.
I would like to test the cables by cable-diagnostics tdr.
SW-FRPAU-X00I1B-AUSR#sh cable-diagnostics tdr interface Gi1/0/11
TDR test last run on: February 07 10:51:16
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/11  100M   Pair A     N/A                N/A         Not Completed
                           Pair B     N/A                N/A         Not Completed
                           Pair C     N/A                N/A         Not Completed
                           Pair D     N/A                N/A         Not Completed
Gi1/0/11                     connected    50         a-full  a-100 10/100/1000BaseTX
Does any one know why it 's Not Completed  please ?
Many thanks,
7 Replies 7
Mark Malone
have a look at this post it may help , very detailed on tdr
https://supportforums.cisco.com/document/74231/how-use-time-domain-reflectometer-tdr
Hi mark,
I already did, but it does unswear my question i am afraid.
have your tried the below from the doc ? if you connect direct to the switch bypass the patch panel does it work  ?
Not completed, on a Catalyst 3K, usually means the TDR result couldn't be continued because the cable run is bad.
Disconnect the patch cable from the patch panel and run the TDR again.
Looks like there are bugs as well for that model depending on version , if nothing else works it may be worth changing your version depending what your on
https://quickview.cloudapps.cisco.com/quickview/bug/CSCtl71772
is there any way to stop the TDR ?
GigabitEthernet3/0/xx is up, line protocol is up (connected: TDR running)
how to stop TDR test ?
Why not answer the question MR. CCIE? The provided link does NOT answer the question. If you don't know the answer then don't reply.
Sorry to be critical but I hate non-answers to legitimate questions not all professionals can afford to purchase the Cert you have. Doesn't mean we aren't qualified just no time or money to afford to take the time off to work on certs
johnlloyd_13
Level 11
Level 11
hi,
can you 'bounce' the port? shut/no shut
I did bounce the port but when it came back up, the TDR started again
