Cisco mds question
owankping22
Has anyone been able to successfully remove switchport fill-pattern idle speed 8000 command? When i put no in front of it, it says invalid command and not been able to find a way to default the interface.
We replaced 8gb sfp with 32gb ones but this command still persists even when you shutdown the port to try and remove that command.
Appreciate any help. Thanks
Mark Elsen
  - Sometimes you have 'default interface ...' to force to go to a default interface setting , if available you could try it and
    configure the needed settings again ,
   M.
