Cisco ME 3400 series nvram crashed
HackHock
Good day. I have a Cisco multilayer switch ME 3400 24TS-A and i have a problem with nvram. In the NVRAM is 0 bytes memory and switch does not created nvram files. there is a description from switch when i write a command dir nvram: Please can help me
*Mar 1 00:00:04.177: %IFS-3-FS_CREATE_FAIL: Failed to create nvram file system, no NVRAM present
-Traceback= 1F93ECC 1F94588 1E60F50 1FCCDEC 1FCD5D0 1FCDA18 1FCC500 1FC9218 1FCA140 1FCA598 1FCE3BC 1E5E01C 1F97260 22178C0 2217958 1DCF3FC
*Mar 1 00:00:04.177: %PRST_IFS-3-GENERAL: persistent media IFS general error: Open Read - can't open nvram:persistent-data errno is 21
*Mar 1 00:00:32.371: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar 1 00:00:33.529: %SPANTREE-
00:01:54 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 1F982 54
-Traceback= 1F98254 1F96BF4 1E62B0C 1E5EE10 1E7BDF0 1E7BF84 1D3A058 1D38F6C 1D48 E54 1D49350 1D4971C 1D4E598 1D79EA8 22948B0 228B084
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_9
=== Flushing messages (00:01:57 UTC Mon Mar 1 1993) ===
Buffered messages:
-Traceback= 1F93ECC 1F94588 1E60F50 1FCCDEC 1FCD5D0 1FCDA18 1FCC500 1FC9218 1FCA 140 1FCA598 1FCE3BC 1E5E01C 1F97260 22178C0 2217958 1DCF3FC
*Mar 1 00:00:04.177: %PRST_IFS-3-GENERAL: persistent media IFS general error: O pen Read - can't open nvram:persistent-data errno is 21
*Mar 1 00:00:32.371: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha nged state to down
*Mar 1 00:00:33.529: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for typ e vlan
*Mar 1 00:00:54.400: %SYS-5-RESTART: System restarted --
Cisco IOS Software, ME340x Software (ME340x-METROACCESSK9-M), Version 12.2(55)SE 11, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Wed 17-Aug-16 15:13 by prod_rel_team
Queued messages:
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x015251A4 SRR1 = 0x00029230 SRR2 = 0x01F98254 SRR3 = 0x00029230
ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x84000000 DBSR = 0x01000000
CPU Register Context:
Vector = 0x00002000 PC = 0x01F98254 MSR = 0x00029230 CR = 0x30005003
LR = 0x01F96BF4 CTR = 0x01F96B94 XER = 0x80000000
R0 = 0x01F96BF4 R1 = 0x03BA5640 R2 = 0x00000000 R3 = 0x00000000
R4 = 0x03556286 R5 = 0x03BA56A0 R6 = 0x035562A6 R7 = 0x035562C6
R8 = 0x035562D6 R9 = 0x00000000 R10 = 0x0355631C R11 = 0x04445958
R12 = 0x00000000 R13 = 0x00110000 R14 = 0x01D792B8 R15 = 0x00000000
R16 = 0x034FC59C R17 = 0x034FC59C R18 = 0x00000001 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x031B0000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x03BA57A0 R27 = 0x038E7384
R28 = 0x00000006 R29 = 0x00000000 R30 = 0x00000000 R31 = 0x00000000
Stack trace:
PC = 0x01F98254, SP = 0x03BA5640
Frame 00: SP = 0x03BA5658 PC = 0x01E68290
Frame 01: SP = 0x03BA5670 PC = 0x01F96BF4
Frame 02: SP = 0x03BA5690 PC = 0x01E62B0C
Frame 03: SP = 0x03BA56E8 PC = 0x01E5EE10
Frame 04: SP = 0x03BA5760 PC = 0x01E7BDF0
Frame 05: SP = 0x03BA57C0 PC = 0x01E7BF84
Frame 06: SP = 0x03BA5828 PC = 0x01D3A058
Frame 07: SP = 0x03BA5860 PC = 0x01D38F6C
Frame 08: SP = 0x03BA5878 PC = 0x01D48E54
Frame 09: SP = 0x03BA58A8 PC = 0x01D49350
Frame 10: SP = 0x03BA58B8 PC = 0x01D4971C
Frame 11: SP = 0x03BA58D0 PC = 0x01D4E598
Frame 12: SP = 0x03BA5968 PC = 0x01D79EA8
Frame 13: SP = 0x03BA5970 PC = 0x022948B0
Frame 14: SP = 0x00000000 PC = 0x0228B084
Switch uptime is 2 minutes, 1 second
cisco ME-3400-24TS-A (PowerPC405) processor (revision D0) with 131072K bytes of memory.
Processor board ID FOC1333W2CS
Boot Sector Filesystem (bs) installed, fsid: 2
Base ethernet MAC Address: 00:26:ca:4d:2d:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
*** The system will autoboot in 5 seconds ***
Send break character to prevent autobooting.
Initializing Flash...
flashfs[0]: 19 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 11672064
flashfs[0]: Bytes available: 20841984
flashfs[0]: flashfs fsck took 7 seconds.
...done Initializing Flash.
done.
Loading "flash:me340x-metroaccessk9-mz.122-55.SE11.bin"...@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:me340x-metroaccessk9-mz.122-55.SE11.bin" uncompressed and installed, entry point: 0x1000000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Image text-base: 0x01000000, data-base: 0x02600000
Initializing flashfs...
flashfs[1]: 19 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32514048
flashfs[1]: Bytes used: 11672064
flashfs[1]: Bytes available: 20841984
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
Error reading config file "flash:/config.text"
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Last reset from address error
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:26:CA:4D:2D:00
Motherboard assembly number : 73-9866-11
Power supply part number : 341-0148-01
Motherboard serial number : FOC133311DF
Power supply serial number : DTH1330314X
Model revision number : D0
Motherboard revision number : A0
Model number : ME-3400-24TS-A
System serial number : FOC1333W2CS
Top Assembly Part Number : 800-26320-02
Top Assembly Revision Number : A0
Version ID : V02
CLEI Code Number : COMFR00BRA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 ME-3400-24TS-A 12.2(55)SE11 ME340x-METROACCESSK9-M
Press RETURN to get started!
*Mar 1 00:00:04.194: %IFS-3-FS_CREATE_FAIL: Failed to create nvram file system, no NVRAM present
*Mar 1 00:00:04.194: %PRST_IFS-3-GENERAL: persistent media IFS general error: O pen Read - can't open nvram:persistent-data errno is 21
*Mar 1 00:00:32.405: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha nged state to down
*Mar 1 00:00:33.562: %SPANTREE-
--- System Configuration Dialog ---
Enable secret warning
In order to access the device manager, an enable secret is required
If you enter the initial configuration dialog, you will be prompted for the enab le secret
If you choose not to enter the intial configuration dialog, or if you exit setup without setting the enable secret,
please set an enable secret using the following CLI in configuration mode-
enable secret 0 <cleartext password>
---------5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar 1 00:00:54.442: %SYS-5-RESTART: System restarted --
Compiled Wed 17-Aug-16 15:13 by prod_rel-------------------------
Would you like to enter the initial configuration dialog? [yes/no]: _teamn
Switch>enable
Switch#
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: System previously crashed with the following message:
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: Cisco IOS Software, ME340x Software (ME340x-METROACCESSK9-M), Version 12.2(55)SE11, RELEASE SOFTWARE (fc3)
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: Technical Support: http://www.cisco.com/techsupport
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: Copyright (c) 1986-2016 by Cisco Systems, Inc.
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: Compiled Wed 17-Aug-16 15:13 by prod_rel_team
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: SRR0 = 0x015251A4 SRR1 = 0x00029230 SRR2 = 0x01F98254 SRR3 = 0x00029230
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x84000000 DBSR = 0x01000000
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: CPU Register Context:
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: Vector = 0x00002000 PC = 0x01F98254 MSR = 0x00029230 CR = 0x30005003
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: LR = 0x01F96BF4 CTR = 0x01F96B94 XER = 0x80000000
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: R0 = 0x01F96BF4 R1 = 0x03BA5640 R2 = 0x00000000 R3 = 0x00000000
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: R4 = 0x03556286 R5 = 0x03BA56A0 R6 = 0x035562A6 R7 = 0x035562C6
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: R8 = 0x035562D6 R9 = 0x00000000 R10 = 0x0355631C R11 = 0x04445958
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: R12 = 0x00000000 R13 = 0x00110000 R14 = 0x01D792B8 R15 = 0x00000000
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: R16 = 0x034FC59C R17 = 0x034FC59C R18 = 0x00000001 R19 = 0x00000000
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x031B0000
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: R24 = 0x00000000 R25 = 0x00000000 R26 = 0x03BA57A0 R27 = 0x038E7384
*Mar 1 00:01:54.663: %PLATFORM-1-CRASHED: R28 = 0x00000006 R29 = 0x00000000 R30 = 0x00000000 R31 = 0x00000000
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Stack trace:
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: PC = 0x01F98254, SP = 0x03BA5640
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 00: SP = 0x03BA5658 PC = 0x01E68290
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 01: SP = 0x03BA5670 PC = 0x01F96BF4
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 02: SP = 0x03BA5690 PC = 0x01E62B0C
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 03: SP = 0x03BA56E8 PC = 0x01E5EE10
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 04: SP = 0x03BA5760 PC = 0x01E7BDF0
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 05: SP = 0x03BA57C0 PC = 0x01E7BF84
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 06: SP = 0x03BA5828 PC = 0x01D3A058
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 07: SP = 0x03BA5860 PC = 0x01D38F6C
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 08: SP = 0x03BA5878 PC = 0x01D48E54
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 09: SP = 0x03BA58A8 PC = 0x01D49350
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 10: SP = 0x03BA58B8 PC = 0x01D4971C
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 11: SP = 0x03BA58D0 PC = 0x01D4E598
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 12: SP = 0x03BA5968 PC = 0x01D79EA8
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 13: SP = 0x03BA5970 PC = 0x022948B0
*Mar 1 00:01:54.672: %PLATFORM-1-CRASHED: Frame 14: SP = 0x00000000 PC = 0x0228B084
5 Replies 5
Mark Malone
It looks as if the NVRAM mod is dead , it happened on a switch before we needed to replace it , do you have this router under support for RMA ?
I do not because this switch is from my friend. How to it check?
Ok i checked Ciscos page the device is EOL this month so unless your friend has it supported under a 3rd party , its likely not supported with Cisco , you could call Cisco provide the serial number but if its out of support in 15 days with them your friend probably doesn't have it backed out to them , you could ask your friend
https://www.cisco.com/c/en/us/products/collateral/switches/me-3400-series-ethernet-access-switches/end_of_life_notice_c51-726108.html
Last Date of Support:
HW
The last date to receive applicable service and support for the product as entitled by active service contracts or by warranty terms and conditions. After this date, all support services for the product are unavailable, and the product becomes obsolete.
January 31, 2019
Ok thanks and i asked him. Can be some repair this problem
And it happened after update iOS in switch
