Cisco ME 3400 Series
saroj pradhan
i have  Cisco ME3400 series switch  .Unable to login as i have no user name and password.  I want to set the swirch to factory default but not found any  nub to press .please help.
Saroj
Sandeep Choudhary
HI Saroj,
To reset the switch:
At the switch prompt, enter enable, and press Return or Enter.
At the Privileged EXEC prompt, switch#, enter setup and press Return or Enter.
Please rate if it helps.
if you are satisfied with answer then please marked as answered, may be it help others.
please rate if it helps.
