how 2 reach a target network that is not in routing table using route-map
dannan lin
I have following questions here.
When default route is pointed at R2 the
traffic source from vlan 10 designated for office1 (20.20.20.0) should be routed to R3 .
The f1/0 on R1 is a layer 2 interface, R4 is acting as a PC and its gateway is a SVI address (10.1.3.1) on R1.
The routing table on R1 is like this
Gateway of last resort is 10.1.1.1 to network 0.0.0.0
     10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C       10.1.3.0/24 is directly connected, Vlan10
C       10.1.2.0/30 is directly connected, FastEthernet0/1
C       10.1.1.0/30 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 10.1.1.1
Route map on R1 is like this
route-map R3, permit, sequence 10
Match clauses:
   ip address (access-lists): 101
Set clauses:
   ip next-hop 10.1.2.1
   ip next-hop verify-availability
Policy routing matches: 150 packets, 10226 bytes
Access-list on R1 is like this
R1(config)#do show access-list
Extended IP access list 101
   10 permit ip 10.1.3.0 0.0.0.255 20.20.20.0 0.0.0.255 (153 matches)
I also forced local policy
ip local policy route-map R3
I applied policy on vlan 10
interface Vlan10
ip address 10.1.3.1 255.255.255.0
ip policy route-map R3
The routing table on R3 is like this
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
     20.0.0.0/24 is subnetted, 1 subnets
C       20.20.20.0 is directly connected, Loopback99
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       10.1.2.0/30 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 is directly connected, FastEthernet0/0
R4’s routing table is like below
R4(config)#do show ip route
S       20.20.20.0 [1/0] via 10.1.3.1
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.3.0 is directly connected, FastEthernet0/0
As you can see there are matching clauses, but I couldn’t ping 20.20.20.20 sourced from vlan 10. I do not want to add 20.20.20.0 network into routing table because if I do so the whole routing map thing would be pointless. So I want to know how to reach 20.20.20.0 network without add extra entry into routing table.
This question is driving me crazy.
Any help is appreciated.
4 Accepted Solutions
John Blakley
Does your 20.20.20.0 network know how to get back to the 10.1.3.0 subnet?
HTH, John *** Please rate all useful posts ***
definitely you need to have policy based routing in this scenario. also you should have the static route on the r3 as well to reach the r4 to make this work. in pbr access-list even you can specify the traffic based on the hosts and ports if you want. So from the r4 svi vlan 10 all the other traffic would pass via r2 by default... what ever you mention in the access-list of route map to the next hop pointed address would be passing via r3 in ur case..... it should work if you configyre in such a way like this.....
Is the device you're doing PBR on a L3 switch or a router with a switching module ?
Is cdp enabled on this device and on the interface pointing towards next-hop ?
Regards.
Alain.
Yes of course because if you're using next-hop reachability without IP sla then cdp is used and if it is disabled then the next-hop is not available and it uses normal routing table.
Regards.
Alain.
15 Replies 15
John Blakley
thanks for your reply, i think i do have  a default route on R3 (0.0.0.0 0.0.0.0 10.1.2..2).
i paste my config again hope problem can be soloved.
R1 route-map
R1(config)#do show route
route-map 2R3, permit, sequence 10
Match clauses:
   ip address (access-lists): office
Set clauses:
Policy routing matches: 5 packets, 570 bytes
R1 routing table
R1 access-list
Extended IP access list office
   10 permit ip 10.1.3.0 0.0.0.255 20.20.20.0 0.0.0.255 (5 matches)
R4 routing table
Gateway of last resort is 10.1.3.1 to network 0.0.0.0
S       20.20.20.0 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 10.1.3.1
R3 routing table
R3(config)#do show ip route
Gateway of last resort is 10.1.2.2 to network 0.0.0.0
     10.0.0.0/30 is subnetted, 1 subnets
C       10.1.2.0 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 10.1.2.2
interface FastEthernet1/0
switchport access vlan 10
interface Vlan10
ip policy route-map 2R3
I have added the default route at R3
i think the route-map actually worked,  the traffic from R4 will be checked by route-map before routing table thus it can reach R3,   and R3 has a default route points at R1 and R1 can reach R4 wihtout problems. R3 has default route points at R1as well.
everything looks alright to me, but I still cannot make it work. I have been thinking this overnight still no clue. please help. much appreciated.
thanks for your reply j, i have added the default route at both  R3 and R4 , but it didn't work . i have no idea. please help.
Hi Dannan,
everything looks good for me....
you can add a static route in r3 like the below and check if this works....
ip route 10.1.3.0 255.255.255.0 10.1.2.2
hi: karthikeyan, i have added static default route on both R4 and R3.
R4:
R3:
it is not work as expected. i am still working on it. thanks for your reply.
Hi Dannan,
i dont want you to have a default route... try with the static route specifying the destination subnet like the below on the R3
Pramod Thakuria
Hi Dannan,
There is no need to add static route on R3 and R4.
You can add a reverse route map on R1's interface fa0/1.
Try this...
Route Map:
route-map R2
match ip address test
set ip next-hop  10.1.3.1
ACL:
access-list 102 permit ip 20.20.20.0 0.0.0.255 10.1.3.0 0.0.0.255
Hi Pramod,
Yes as u said you need a reverse route to achieve this.... its ebasy to have static route rather than policy based route.... both the things should work...
Regards.
Alain.
hi cadet : i am doing PBR on a L3 switch and cdp disabled. does it matter? thanks for your reply.
Regards.
Alain.
hi : thanks for all of your help, i finally got it work. the problem doesn't not appear to be with the configuration. it is something to do with the GN3 equipments i choosen.
the L3 switch does not work but Router with additional module works.but i have no idea why was that?
again much appreciate all your helps especially cadet, you gave me the hint.
hi pramod:
thank for your hint, i will definately try to add another RM to it. i will get back to you if it works.  appreciate your help.
