Cisco Network Switch
Philip-emaikwu
Community Member
I have a question concerning the Cisco Network Switch , recently we are required to put some of our equipment in the storage for an extend period up to a year in storage. My question is that, how long will these Cisco Network Switch module remain in storage unpowered before they lose memories? Do you guys have a recommended time that the Network Switch's can sit unpowered before they lose memory or become unusable?
Best regards.
Reza Sharifi
The configuration is in NVRAM and not memory. So, it will never get lost. Think of NVRAM as a hard drive. It will always be there unless you power up the switch and earase it.
balaji.bandi
Not that i am aware or faced any issue, you loose the configuration due to no usage of device.
even you loose the configuration, take the configuration backup before you turn off the devices.
BB
Reza Sharifi
Joseph W. Doherty
Personally, I suspected years to decades.  Obtained the following AI answer to such a question, which appears to support my suspicion.
Very likely a year in storage would be a non-issue, but as @balaji.bandi suggests, having separate backup of NVRAM data would be advisable.
How long does nvram retain memory
NVRAM (Non-Volatile Random Access Memory) retains its memory for a significant amount of time, even when the power is turned off. The exact retention time varies depending on the type of NVRAM and the specific implementation.
Up to 10 years: According to some sources, NVRAM chips can retain their data for up to 10 years without significant degradation. This is because NVRAM is designed to store data in a non-volatile manner, meaning it doesn’t require power to maintain the stored information.
20-40 years: In some cases, NVRAM can retain its memory for up to 20-40 years, as mentioned in a Reddit thread discussing the need for non-volatile memory with extremely long service life.
Long-term storage: NVRAM is often used in applications where long-term storage is required, such as in devices with limited power sources, like laptops and smartphones. In these cases, NVRAM can retain its memory for extended periods without significant degradation.
Factors affecting retention time: The retention time of NVRAM can be affected by various factors, including:
  • Quality of the NVRAM chip
  • Environmental conditions (temperature, humidity, etc.)
  • Power cycling (turning the device on and off repeatedly)
  • Data retention mechanisms (e.g., periodic rewriting or refreshing)
In summary, NVRAM can retain its memory for a significant amount of time, ranging from up to 10 years to 20-40 years, depending on the specific implementation and environmental conditions.
AI-generated answer. Please verify critical facts. Learn more
