Cisco nexos 9.37 int vlan 1 not able to ping gateway
We have sonic wall firewall enabled dot1q with sub interface vlan 1 vlan 2 vlan 3 vlan 21 and vlan 22 on nexus switch we have enabled inter vlan feature and configured interface vlan 1 with ip address 192.168.1.254 and default route point to sonic wall interface ip address 192.168.1.1 when we try ping to 192.168.1.1 getting destination host not reachable and no route found
20 Replies 20
Pavel Tarakanov
How firewall and the switch connected? Please provide configuration for ports used for connection.
Most likely you need to move ports to switchport mode:
int eth 1/1
switchport
switchport mode trunk
M02@rt37
Hello @arunkumarunique86
What about hte Cisco Interface's config ? It should be a Trunk mode.
Also you ant to ping a Firewall... ensure that policy allowed this and check also from SonicWall if you see icmp echo-request.
Best regards
our ethernet 1/1 is connected to the pc with ip address 192.168.1.6/24 was able to ping both interface vlan 1 192.168.1.254 and sonic firewall interface ip address 192.168.1.1
Check mac address and arp table for correct records.
arp comes out incomplete
Can switch ping/resolve ARP for any other host in this VLAN?
on nexus switch
interface eth1/47
switchport trunk allowed vlan 1-25
exit
interface vlan 1
ip address 192.168.1.254/24
no shut
exit
ip route 0.0.0.0 0.0.0.0 192.168.1.1
end
ping 192.168.1.1
i am getting destination host unreachable we ping 192.168.1.1 from switch is there any feature need to be enabled or disabled
@arunkumarunique86
On Switch, ping 192.168.1.1 source 192.168.1.254 failed ?
Best regards
yes failed also
@arunkumarunique86
clear ARP table
and retry
Best regards
tried few times still the same
i can give you remote access through team viewer tomorrow morning 9:00 am Singapore time
anything we are missing out
