Cisco Nexus 2XXX vs HP ProCurve.
andrea.meconi
Level 2
Level 2
Hello.
My customer want to connect a HP ProCurve 2920 switch to a Nexus 2XXX using link aggregation.
Can someone suggest how?
Thanks.
Regards.
Andrea
Reza Sharifi
The 2k ports are designed for end device connectivity e.g servers, workstations, printers, etc.. and not for switch to switch connectivity.  The 2ks need a parent switch (5k, 6k or 7k) and so you can directly connect the HP 2920 to the parent switch instead.
Reza Sharifi
Many thanks Reza.
So if I understand well I can connect to the parent switch using LACP...
Regards.
Andrea
That is correct.  All parent switches support LACP.  You would need to look at the HP switch and make sure LACP is supported.
Many many thanks for your help Reza.
HP ProCurve and Comware switches support LACP.
Regards.
Andrea
