09-20-2017 07:21 PM - edited 03-08-2019 12:06 PM
Hi All,
Our Cisco Nexus 4001I Switch Module for IBM BladeCenter has reloaded its own, when i checked the logg what i found is below. Can you suggest which version has a fix?
CCC-DRBC-4k-B# sho logging nvram
2017 Sep 14 10:48:57 CCC-DRBC-4k-B %SYSMGR-2-SERVICE_CRASHED: Service "snmpd" (PID 2568) hasn't caught signal 6 (core will be saved).
2017 Sep 14 10:51:09 CCC-DRBC-4k-B %KERN-2-SYSTEM_MSG: Starting kernel... - kernel
2017 Sep 14 10:51:09 CCC-DRBC-4k-B %KERN-1-SYSTEM_MSG: Entered kgdb_console_init:1960 - kernel
2017 Sep 14 10:52:02 CCC-DRBC-4k-B %VDC_MGR-2-VDC_ONLINE: vdc 1 has come online
CCC-DRBC-4k-B# sho pro log pid 2568
Service: snmpd
Description: SNMP Agent
Started at Sat Jun 17 21:38:15 2017 (364501 us)
Stopped at Thu Sep 14 10:48:57 2017 (520724 us)
Uptime: 88 days 13 hours 10 minutes 42 seconds
Start type: SRV_OPTION_RESTART_STATELESS (23)
Death reason: SYSMGR_DEATH_REASON_FAILURE_SIGNAL (2)
Last heartbeat 7.95 secs ago
System image name: n4000-bk9.4.1.2.E1.1b.bin
System image version: 4.1(2)E1(1b) S0
PID: 2568
Exit code: signal 6 (core dumped)
Threads: 2832
CWD: /var/sysmgr/work
Virtual Memory:
CODE 10000000 - 100D1138
DATA 10075000 - 100D1138
BRK 100DD000 - 17E10000
STACK 7FFFFA10
TOTAL 195416 KB
Register Set:
GPR0 000000FA GPR1 7FFFD820 GPR2 3003D720 GPR3 00000000
GPR4 00000A08 GPR5 00000006 GPR6 00000000 GPR7 0E3DE588
GPR8 300362C0 GPR9 FFFFF5F8 GPR10 00000000 GPR11 7FFFD7F0
GPR12 0E3DFCE0 GPR13 100D90E8 GPR14 000002A0 GPR15 10060000
GPR16 10060000 GPR17 10060000 GPR18 10060000 GPR19 7FFFF740
GPR20 00000001 GPR21 102C78E4 GPR22 00000000 GPR23 102CA5BC
GPR24 00000000 GPR25 00000047 GPR26 00000000 GPR27 0000024C
GPR28 0E4F0274 GPR29 300362C0 GPR30 0E4EDFB4 GPR31 00000006
**bleep** 0E3DE2F4 MSR 0002D000 GPR3O 00000A08 CTR 0EE7A260
LINK 0E3DFCE0 XER 00000000 CCR 44042424 MQ 00000000
TRAP 00000C00 DAR 0E3DFAAC DSISR 00000000 RES 00000000
Stack: 8192 bytes. ESP 7FFFD820, TOP 7FFFFA10
Mohan
Solved! Go to Solution.
09-21-2017 03:53 AM
09-20-2017 11:52 PM
can you post the output of:
show proc log pid 2568
09-21-2017 12:03 AM
09-21-2017 12:16 AM
thanks for the output. The reload is caused by the SNMP daemon. Usually, there is an indication in one of the lines of your output of what causes this:
0x7FFFE080: 43723374 3361646D 316E0000 103159D4 Cr3t3adm1n...1Y.
That looks like some sort of user ID, do you have an SNMP server installed somewhere ? What is the (SNMP part of) the configuration of your switch, can you post that ?
09-21-2017 12:22 AM
Yes, That is our snmp community string.
CCC-DRBC-4k-B# sho run | in snmp
snmp-server user admin network-admin auth md5 xxxx priv xxx localizedkey
snmp-server user cresupport network-admin auth md5 xxx priv xxxx localizedkey
snmp-server community Cr3t3adm1n group network-operator
CCC-DRBC-4k-B#
09-21-2017 12:32 AM
can you find out which port the SNMP server is connected to ? Maybe something simple like rebooting that server could resolve this.
09-21-2017 12:51 AM
09-21-2017 03:53 AM
4.1(2)E1(1c) is listed as a version containing a fix...
