Cisco Nexus 5000 ACL log Problem
We work with two Cisco Nexus 5548 with ACLs configured on VLANs.
Software Version is: 5.1(3)N2(1)
The ACLs are working fine. But our problem is, that in the logs on the switch, on Server or console/monitor does not appear.
when i configure things like: logging server [IP] 7 // logging monitor 7 -> no Log entry appears on the server nor on the monitor telnet session.
Did anyone know of problems with this version or a special config?
Also commands like "show logging ip access-list" does not work.
We also cannot set the command log after a acl line...
Does anyone know something about a feature, extra Card/license or something like that?
there are also no acl logs in the switch logfile (show Log)
Thanks in advance for your help
nobody an idea or the same problem with a solution?
Thomas did you ever find a solution to this issue?
