Track command to disable/enable port with conditional if
cjsattler
Community Member
I am trying to figure out how to do a track of reachability for an ip and then if it fails switch the port to a different port.
For example, i have a vlan interface and two layer two switchports with separate paths to a different location, one on gig1/1 and one on gig1/2
If a ping stops to the remote location i want to disable port 1/1 and enable port 1/2.
if port 1/2 is enabled and pinging stops, i want to enable 1/1 and disable port 1/2
ill have it count down on a timer for about 10 minutes to make sure arp isnt an issue.
also no, im not able to enable spanning tree to figure this out.
0 Replies 0
