Cisco Nexus 5000 and LACP
Vinny
I have a pair of Nexus 55594UP with several fexes dual homed.
I have configured a lot of LACP port-channel without problem with a lot of servers. We installed a new Sun Solaris several weeks ago with this config and it works great.
Now we need to install a second Sun Solaris and it doens't works well.
Setup :
One port-channel of two 10gb NIC directly connected in each N5k.
Multiple port-channels of two 1gb NIC connected to the same fex.
The problem is, on all port-channels of this server, one port is "P" and the other is "I" for 1gb cards (#13-14-17). For the 10gbs port-channel (#9), I see "I" on both Nexus
# sh port-channel summary
9     Po9(SD)     Eth      LACP      Eth1/6(I)
13    Po13(SU)    Eth      LACP      Eth111/1/7(I)  Eth111/1/8(P)
14    Po14(SU)    Eth      LACP      Eth111/1/9(I)  Eth111/1/10(P)
17    Po17(SU)    Eth      LACP      Eth111/1/1(P)  Eth111/1/2(I)
Config for the 10gb (same on both N5k)
interface port-channel9
  description CT20SSLDCP01
  switchport access vlan 2
  spanning-tree port type edge
  vpc 9
interface Ethernet1/6
  channel-group 9 mode active
Config for the 1gb port-channels :
interface port-channel13
  switchport access vlan 12
interface Ethernet111/1/7
  channel-group 13 mode active
interface Ethernet111/1/8
_____________________________________________________
interface port-channel14
  switchport access vlan 13
interface Ethernet111/1/9
  channel-group 14 mode active
interface Ethernet111/1/10
interface port-channel17
  switchport access vlan 3
  channel-group 17 mode active
interface Ethernet111/1/2
Do you have any idea ?
On the server we see this message too, which is weird because these aggr and ports numbers doesn't exist on the server and these numbers change randomly :
Jul 25 10:03:30  CT20SSLDCP01 aggr: NOTICE: aggr 45 port  15: Port Partner MAC 0:23:4:ee:be:1 and key 13 in use on aggregation 47 port  18
Jul 25 10:03:31  CT20SSLDCP01 aggr: NOTICE: aggr 45 port  13: Port Partner MAC 0:23:4:ee:be:1 and key 10 in use on aggregation 47 port  8
Thanks !
Roberto Rodriguez
Hello Vincent,
Would you please post here the following outputs this seems to be a problem with the Solaris not using LACP.
show lacp counters interface po 13
show lacp counters interface po 14
show lacp counters interface po 17
show lacp neighbor interface po 13
show lacp neighbor interface po 14
show lacp neighbor interface po 17
Robert Rodriguez
