Cisco Nexus 5000 upgrade
glen.grant
    Is there any gotchas or things we should know when going from version  5.1(3)N2(1)   to a  7.X level code ?   Is it as simple as getting the code and kickstarter images on and then using the install command.  these are all single supervisor module boxes .  We are using single  attached fexes on these also .   I have read the install procedures and didn't seem to see anything while reading as an issue . This is the first time we have done the Nexus boxes so I wanted to throw this out there to people that have done this before .  Thanks ...
Reza Sharifi
There is nothing special about the upgrade.  The nice thing about 5ks is that they come with a USB ports.  So just load the images from USB to the switch and run the install command.
Good Luck
Reza
