Cisco Nexus 5010
goransh_pc
I saw a Cisco Nexus 5010 and it has 5 RJ-45 port, 1 for Console, 2 for MGMT and another two port for what ??? L1 and L2, somebody can explain me that ?? Thank yuo so much !!!
Konus,
The defect id is to document that the ports are not usable, this was not documented. ( did not intend to confuse you).
The first 8 ports on 5010 can be used to as 1 gig ports with GLC-T= transceiver.
JayaKrishna
Jayakrishna Mada
Hi ,
Only one port works our of those 4 ports. L1/L2/MGMT1 are not usable yet and will be used in future. A document defect is opened to document this. Defect id: CSCth37349
Hope that answers your question.
JayaKrishna
Thank you so much for your quick feedback JayaKrishna, but right now I'm more confused than before:
Waht is a Defect ID: CSCth37349 ?
All usable ports on that switch (Nexus) are SFP, is there any adapter that permits to connect NIC server or NIC pc to the Nexus through RJ-45 and UTP cable?
Thank you so much
Konus,
JayaKrishna
Thank you So Much Jaya.
