Cisco Nexus 5020 - "[00]" via console using Termite
G4L3A
Hi Guys,
I have a Cisco Nexus 5020 which, when first power on, doesn't provide anything via console instead of the following: "[00]" (using Termite). It seems that the switch doesn't complete its boot sequence and fails to initiate the SFP port self checks.
The switch appears to be DOA. Has anyone else experienced something like this?
I have provided a video of the switch powering up: https://drive.google.com/file/d/16fJ3abh3Aua0cBOVFRtHrZ4cyGSeFLPr/view
Thanks!
5 Replies 5
Ben Samayoa
Hi there,
Try a different console terminal such as Tera-Term or putty, connect the console and restart it and wait if
anything shows up on the screen. It will definitely shows something there.
regards,
Ben
Hi Ben,
Putty and Tera-term have been tried previous to Termite, and nothing is presented via the console interface. It doesn't respond to any input whatsoever. Termite has been the only client to present anything, even if its a hex representation of null ([00]).
Cheers!
Was it working ok prior this issue?
Hi Ben,
Yes, I can confirm that it was working prior to this issue. Its very unusual that, all of a sudden, the switch is no longer responding to console input. It was shipped to another individual after being sold, and appears to have been "thrown around by Fedex" during transit - I suspect something may have happened.
Cheers!
Hi there again!
It is most likely been dropped and that is the cause of the failure.
I never seen one of them with a similar issue.
You will have to returned it to sender as a DOA - damaged in transit.
Funny enough i got a different device damaged in transit couple of days ago same courier.
Box was dropped by the looks of it - and poorly packed.
Best of luck.
regards,
Ben
