Cisco Nexus 7000 BGP default route distribution
CiscoNutt
I am trying to configure BGP on a Nexus 7000 to distribute a default route to several VRFs, however I am unable to find a command to do this.  Any ideas would be greatly appreciated.
7 Replies 7
Harold Ritter
You can try the following:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/unicast/configuration/guide/l3_advbgp.html#wp1154404
Thanks for your reply.
The issue is I do not have the option to enter the default-information originate in BGP...this command is not present.  We are running version 6.1(2) and have several VDCs configured...if that makes a difference (I doubt it).  Any ideas as to why this command is not present? perhaps I need to enable another feature?
Also we have several VRFs configured, which are the ones I am trying to have the configured default route advertised for each of those VRFs.
It looks like the only way to generate the default  route in a VRF in this version of nx-os is to use a networ statement (network  0.0.0.0/0). You will obviously need to have a default route present in  the RIB for the specific VRF.
Hi thanks again.
I found the command to distribute the default route:
router bgp 10
neighbor 10.10.10.10
address-family ipv4 unicast
default-originate
However this distributes the global default route and not for the individual VRFs.  I had originally configured static default routes under the VRF process on the edge switches, but that did not work.  I removed the bgp process and added it again and things worked.  so not sure why it did not work the first time...guess I will never know.
Thanks for your replies
The command you found is for the global context and is not available in a VRF context. Did you try using a network statement as I suggested?
No I did not try the network statement. I did however remove and then add the default route I had configured under the VRF context and then the route was added to the routing table.  I am not sure why it was not added the first time.  Anyway, things are working now. thanks for your replies.
