cisco nexus 7000 - no int range command
robertkwild
hi all,
i have configured ciscos before and i can normally configure a range of interfaces like -
conf t
#int range g10/13-24
then my commands...
but this switch seems to not support the range command
thanks,
rob
 - Could you just avoid the range word in your initial command (test)  ?
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 -  Could you leave a blank before and after the hyphen. Check is this helps.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
that wont help as the switch doesnt even have the command for "range"
# int ?
breakout Configuring the breakout for an interface
ethernet Ethernet IEEE 802.3z
loopback Loopback interface
mgmt Management interface
port-channel Port Channel interface
vlan Vlan interface
   M.
       Beauty and terror
      Just keep going
       No feeling is final
nice one!!!!!
it worked
