C6800-8P10G Interface Module Installation on WS-C6509-E
l.marrone
in our core WS-C6509-E (IOS Software- 15.2(1)SY5, supervisor- VS-SUP2T-10G, VSS running) we are planning to install C6800-8P10G Interface Module.
WS-C6509-E modules installed are:
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
  2    8  DCEF2T 8 port 10GE                     WS-X6908-10G
  3    8  DCEF2T 8 port 10GE                     WS-X6908-10G
  4    8  DCEF2T 8 port 10GE                     WS-X6908-10G
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G
  7   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  8    8  DCEF2T 8 port 10GE                     WS-X6908-10G
Do we have compatibility problems between modules installed and C6800-8P10G module or Supervisor Engine 2T 10GE ?
Thanks in advance
Liborio
2 Accepted Solutions
working in one of my vss setups
im running this
s2t54-adventerprisek9_npe-mz.SPA.155-1.SY3.bin"
sh mod
Mod Ports Card Type Model Serial No.
1 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE
2 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE
3 20 DCEF2T 4 port 40GE / 16 port 10GE C6800-16P10G
4 48 CEF720 48 port 1000mb SFP WS-X6748-SFP
8 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX
once the module is supported its supported , it wont interfere with other modules that are supported too , it communicates with the supervisor to come online
all the mods you run are in the supported list in the the document above , you shouldn't have an issue
Table 5. Product specifications
Product
Specifications
Chassis compatibility
● E-Series only: Cisco Catalyst 6503-E, 6504-E, 6506-E, 6509-E, 6509-V-E, 6513E
● C6807-XL
Switch fabric
● 2.08 Tbps Crossbar Switch Fabric with 26 Fabric Channels
Line-card compatibility
● C6800-P10G, C6800-8P10G-XL
● C6800-16P10G, C6800-16P10G-XL
● C6800-32P10G, C6800-32P10G-XL
● C6800-8P40G, C6800-8P40G-XL (only with the C6807-XL chassis, not with the 6500-E chassis)
● WS-X6908-10G-2T, WS-X6908-10G-2TXL
● WS-X6824-SFP-2T, WS-X6824-SFP-2TXL
● WS-X6848-SFP-2T, WS-X6848-SFP-2TXL
● WS-X6848-TX-2T, WS-X6848-TX-2TXL
● WS-X6816-10T-2T, WS-X6816-10T-2TXL
● WS-X6816-10G-2T, WS-X6816-10G-2TXL
● WS-X6904-40G-2T, WS-X6904-40G-2TXL
● WS-X6704-10GE with CFC
● WS-X6724-SFP with CFC
● WS-X6748-SFP with CFC
● WS-X6748-GE-TX with CFC
● WS-X6148A-RJ-45, WS-X6148A-45AF, WS-X6148-FE-SFP, WS-X6148A-GE-TX, WS-X6148A-GE-45AF, WS-X6148E-GE-45AT
With a DFC4 or DFC4XL upgrade (WS-F6k-DFC4-A, WS-F6k-DFC4-AXL)
● WS-X6704-10GE
● WS-X6724-SFP
● WS-X6748-SFP
● WS-X6748-GE-TX
With a DFC4 or DFC4XL upgrade (WS-F6k-DFC4-E, WS-F6k-DFC4-EXL)
● WS-X6716-10G-3C, WS-X6716-10G-3CXL
● WS-X6716-10T-3C, WS-X6716-10T-3CXL
5 Replies 5
im running this
sh mod
Sup-2T support forC6800-8P10G  module is ok, but coexistence between
and C6800-8P10G module could generate any problems ?
Thanks in advance.
Product
Specifications
● C6807-XL
Switch fabric
● WS-X6704-10GE
● WS-X6724-SFP
● WS-X6748-SFP
● WS-X6748-GE-TX
thank you very much
