Cisco Nexus 7K ACL Capture
haitham.jneid
Hi All,
please check if below configuration is applicable on Cisco Nexus 7000. I need to capture all traffic destined to port 80 and copy it to a server for further analysis. I decided to use ACL capture but not sure if this will work.
monitor session 1 type acl-capture
destination interface port-channel10===> hardcoded to on (no use of LACP or PAGP)
no shut
exit
ip access-list TEST_ACL
permit tcp any any eq 80 capture session 1
interface po17.106 ==> the interface on which the traffic is entering the switch.
no shutdown
ip access-group TEST_ACL in
ip address 3.3.3.2/24
is this configuration going to work properly???
regarding the ACL, is it going to capture the TCP traffic destined to port 80 and not impact the production traffic?
appreciate your valuable support.
thanks,
Haitham Jneid
0 Replies 0
