10-04-2022 10:54 AM
Good afternoon,
I have a Cisco Nexus C93180YC-EX inside a closed enclosure that I have to test. I am currently trying to establish a VRF connection between two interfaces (Ethernet1/13 and Ethernet1/15 via copper loopback cable for example) to verify the cable continuity. I previously was using a Cisco Catalyst 3850 so the similarity between the two has not been as close as I would have hoped. Can anyone offer help on what I need to configure and/or enable?
10-05-2022 08:56 AM
Below I have included a configuration I believed would work, however, I was still unable to successfully ping the other interface. Can anyone let me know if maybe there is a feature I need to enable or something in addition the interface configs
Switch#
Switch# conf t
Switch(config)# vrf context TestA
Switch(config-vrf)# show vrf
VRF-Name VRF-ID State Reason
TestA 3 Up --
default 1 Up --
management 2 Up --
Switch(config-vrf)# end
Switch# conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)# int e1/13
Switch(config-if)# vrf member TestA
Warning: Deleted all L3 config on interface Ethernet1/13
Switch(config-if)# ip address 10.10.10.1/24
Switch(config-if)# show vrf TestA int e1/13
Interface VRF-Name VRF-ID Site-of-Origin
Ethernet1/13 TestA 3 --
Switch(config-if)# no shutdown
Switch(config-if)# exit
Switch(config)# vrf context TestB
Switch(config-vrf)# exit
Switch(config)# int e1/15
Switch(config-if)# vrf member TestB
Warning: Deleted all L3 config on interface Ethernet1/15
Switch(config-if)# ip address 10.10.10.2/24
Switch(config-if)# end
Switch# ping 10.10.10.2 source-interface e1/13
PING 10.10.10.2 (10.10.10.2): 56 data bytes
36 bytes from 10.10.10.1: Destination Host Unreachable
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
--- 10.10.10.2 ping statistics ---
5 packets transmitted, 0 packets received, 100.00% packet loss
