Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco nexus 9000 switch
swaminathan
Regarding the cisco nexus 93180YC-Fx switch the data sheet or user manual claims that it supports 1g/10g/25g. But it is not supporting 1g. The ethernet port by default shows that the media type is 10g. I use an intel sfp. Is that the problem or the switch does not support 1g?
Thanks in advance
12 Replies 12
Mark Malone
It does support 1gb I have many of these switch sin use 1gb SFPs in it , GLC-T and GLC-SX use a Cisco SFP
It may not support your intel SFP there is a specific matrix for each switch you can search your switch here
https://tmgmatrix.cisco.com/
We use Intel FTLX8571D3BCVIT1 (E10GSFPSR) SFP https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ethernet-sfp-optics-brief.pdf . It supports both 1G and 10G network standards but media type detected by Nexus switch is 10G alone. It is not clear why Nexus switch could not detect that the media type as 1G/10G.
As i said not on the supported list of SFPs thats why it wont work
here is whats supported , use a Cisco SFP not Intel , these switches support 1GB no pproblem but it needs to be a supported SFP
https://tmgmatrix.cisco.com/?si=93180YC-Fx
N9300
Transceiver Description Software Release
Network Device Product ID Transceiver Product ID Data Rate Form Factor Reach Cable Type Media Connector Type Transceiver Type Case Temp DOM HW Capable Minimum DOM SW
N9K-C93180YC-FX QSFP-100G-SR4-S 100 Gbps QSFP28 100m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y NX-OS 7.03I4.2 NX-OS 7.03I4.2
QSFP-100G-SR4-S 100 Gbps QSFP28 100m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0.1
QSFP-100G-CWDM4-S 100 Gbps QSFP28 2km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 7.03I4.2 NX-OS 7.03I4.2
QSFP-100G-CWDM4-S 100 Gbps QSFP28 2km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0.1
QSFP-100G-PSM4-S 100 Gbps QSFP28 500m Ribbon Fiber SMF MPO-12 Optic 0 to 70C Y NX-OS 7.03I4.2 NX-OS 7.03I4.2
QSFP-100G-PSM4-S 100 Gbps QSFP28 500m Ribbon Fiber SMF MPO-12 Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0.1
QSFP-100G-LR4-S 100 Gbps QSFP28 10km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 7.03I4.2 NX-OS 7.03I4.2
QSFP-100G-LR4-S 100 Gbps QSFP28 10km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0.1
QSFP-100G-SM-SR 100 Gbps QSFP28 2km Duplex Fiber SMF LC Optic 10 to 60C Y NX-OS 7.03I5.1
QSFP-100G-SM-SR 100 Gbps QSFP28 2km Duplex Fiber SMF LC Optic 10 to 60C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0.1
QSFP-100G-ER4L-S 100 Gbps QSFP28 40km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 9.2.1 NX-OS 9.2.1
QSFP-100G-ER4L-S 100 Gbps QSFP28 40km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-14.0(1) ACI-N9KDK9-14.0(1)
QSFP-40/100-SRBD 40/100 Gbps QSFP28 100m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 7.03.I7.3 NX-OS 7.03.I7.3
QSFP-40/100-SRBD 40/100 Gbps QSFP28 100m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y ACI-N9KDK9-13.1.1 ACI-N9KDK9-13.1.1
QSFP-40/100-SRBD 40/100 Gbps QSFP28 70m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 7.03.I7.3 NX-OS 7.03.I7.3
QSFP-40/100-SRBD 40/100 Gbps QSFP28 70m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y ACI-N9KDK9-13.1.1 ACI-N9KDK9-13.1.1
QSFP-100G-CU1M 100 Gbps QSFP28 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-CU1M 100 Gbps QSFP28 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-CU2M 100 Gbps QSFP28 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-CU2M 100 Gbps QSFP28 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-CU3M 100 Gbps QSFP28 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-CU3M 100 Gbps QSFP28 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-CU5M 100 Gbps QSFP28 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-CU5M 100 Gbps QSFP28 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-4SFP25G-CU1M 100 Gbps QSFP28 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-4SFP25G-CU1M 100 Gbps QSFP28 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-4SFP25G-CU2M 100 Gbps QSFP28 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-4SFP25G-CU2M 100 Gbps QSFP28 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-4SFP25G-CU3M 100 Gbps QSFP28 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-4SFP25G-CU3M 100 Gbps QSFP28 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-AOC1M 100 Gbps QSFP28 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC1M 100 Gbps QSFP28 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-AOC2M 100 Gbps QSFP28 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC2M 100 Gbps QSFP28 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-AOC3M 100 Gbps QSFP28 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC3M 100 Gbps QSFP28 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-AOC5M 100 Gbps QSFP28 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC5M 100 Gbps QSFP28 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-AOC7M 100 Gbps QSFP28 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC7M 100 Gbps QSFP28 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-14.1(1) —
QSFP-100G-AOC10M 100 Gbps QSFP28 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC10M 100 Gbps QSFP28 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-AOC15M 100 Gbps QSFP28 15m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC15M 100 Gbps QSFP28 15m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-14.1(1) —
QSFP-100G-AOC20M 100 Gbps QSFP28 20m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC20M 100 Gbps QSFP28 20m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-14.1(1) —
QSFP-100G-AOC25M 100 Gbps QSFP28 25m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC25M 100 Gbps QSFP28 25m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-100G-AOC30M 100 Gbps QSFP28 30m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 7.03I4.2 —
QSFP-100G-AOC30M 100 Gbps QSFP28 30m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-H25G-CU1M 25 Gbps SFP28 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-H25G-CU1M 25 Gbps SFP28 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H25G-CU2M 25 Gbps SFP28 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-H25G-CU2M 25 Gbps SFP28 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H25G-CU3M 25 Gbps SFP28 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-H25G-CU3M 25 Gbps SFP28 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H25G-CU5M 25 Gbps SFP28 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-H25G-CU5M 25 Gbps SFP28 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-25G-AOC1M 25 Gbps SFP28 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-25G-AOC1M 25 Gbps SFP28 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-25G-AOC2M 25 Gbps SFP28 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-25G-AOC2M 25 Gbps SFP28 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-25G-AOC3M 25 Gbps SFP28 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-25G-AOC3M 25 Gbps SFP28 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-25G-AOC5M 25 Gbps SFP28 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-25G-AOC5M 25 Gbps SFP28 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-25G-AOC7M 25 Gbps SFP28 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-25G-AOC7M 25 Gbps SFP28 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-25G-AOC10M 25 Gbps SFP28 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-25G-AOC10M 25 Gbps SFP28 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI N9KDK9-11.3(2) —
SFP-25G-SR-S 25 Gbps SFP28 70m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 703I7.1
SFP-25G-SR-S 25 Gbps SFP28 100m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 703I7.1
SFP-25G-SR-S 25 Gbps SFP28 70m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y ACI N9KDK9-11.3(2)
SFP-25G-SR-S 25 Gbps SFP28 100m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y ACI N9KDK9-11.3(2)
SFP-10G-SR 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-SR 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-SR 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-SR 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-SR-S 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-SR-S 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-SR-S 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-SR-S 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-LRM 10 Gbps SFP+ 220m Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-LRM 10 Gbps SFP+ 300m Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-LR 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-LR 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-LR-S 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-LR-S 10 Gbps SFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-ER 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-ER 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-ER-S 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-ER-S 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-ZR 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-ZR 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-ZR-S 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
SFP-10G-ZR-S 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-10G-BXD-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y NX-OS 703I7.1 —
SFP-10G-BXU-I 10 Gbps SFP+ 10km Single-strand SMF LC Optic -40 to 85C Y NX-OS 703I7.1 —
SFP-10G-BX40D-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y NX-OS 703I7.1 —
SFP-10G-BX40U-I 10 Gbps SFP+ 40km Single-strand SMF LC Optic -40 to 85C Y NX-OS 703I7.1 —
SFP-H10GB-CU1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H10GB-CU1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-H10GB-CU3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H10GB-CU3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-H10GB-CU5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H10GB-CU5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-H10GB-ACU7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H10GB-ACU7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-H10GB-ACU10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H10GB-ACU10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-10G-AOC1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-10G-AOC1M 10 Gbps SFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-10G-AOC2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-10G-AOC2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-10G-AOC3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-10G-AOC3M 10 Gbps SFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-10G-AOC5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-10G-AOC5M 10 Gbps SFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-10G-AOC7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-10G-AOC7M 10 Gbps SFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-10G-AOC10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-10G-AOC10M 10 Gbps SFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
FET-10G 10 Gbps SFP+ 100m Duplex Fiber MMF LC Optic 0 to 70C N NX-OS 703I7.1 —
FET-10G 10 Gbps SFP+ 100m Duplex Fiber MMF LC Optic 0 to 70C N ACI-N9KDK9-12.2(2) —
DWDM-SFP10G-XX.XX 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
DWDM-SFP10G-XX.XX 10 Gbps SFP+ 80km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
CWDM-SFP10G-XXXX 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
CWDM-SFP10G-XXXX 10 Gbps SFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 9.2.1 NX-OS 9.2.1
GLC-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic 0 to 70C N NX-OS 7.0(3)I6(1) —
GLC-T
End Of Sale
10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic 0 to 70C N ACI-N9KDK9-12.2A —
GLC-TE 10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic -5 to 85C N NX-OS 7.0(3)I6(1) —
GLC-TE 10/100/1000 Mbps SFP 100m Cat5e/6A Copper RJ-45 Optic -5 to 85C N ACI-N9KDK9-12.2A —
GLC-BX-D 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
GLC-BX-U 1 Gbps SFP 10km Single-strand SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-SR4 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-SR4 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-SR4 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
QSFP-40G-SR4 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
QSFP-40G-CSR4 40 Gbps QSFP+ 300m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-CSR4 40 Gbps QSFP+ 400m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-CSR4 40 Gbps QSFP+ 300m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
QSFP-40G-CSR4 40 Gbps QSFP+ 400m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
QSFP-40G-SR4-S 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-SR4-S 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-SR4-S 40 Gbps QSFP+ 100m (OM3) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
QSFP-40G-SR4-S 40 Gbps QSFP+ 150m (OM4) Ribbon Fiber MMF MPO-12 Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
QSFP-40G-SR-BD 40 Gbps QSFP+ 100m (OM3) Duplex Fiber MMF LC Optic 10 to 70C N NX-OS 703I7.1 —
QSFP-40G-SR-BD 40 Gbps QSFP+ 150m (OM4) Duplex Fiber MMF LC Optic 10 to 70C N NX-OS 703I7.1 —
QSFP-40G-SR-BD 40 Gbps QSFP+ 100m (OM3) Duplex Fiber MMF LC Optic 10 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-40G-SR-BD 40 Gbps QSFP+ 150m (OM4) Duplex Fiber MMF LC Optic 10 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-4X10G-LR-S 40 Gbps QSFP+ 10km Duplex Fiber SMF MPO-12 Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-LR4-S 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-LR4-S 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
QSFP-40GE-LR4
End Of Sale
40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C N NX-OS 703I7.1 —
QSFP-40GE-LR4
End Of Sale
40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-40G-LR4 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-LR4 40 Gbps QSFP+ 10km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
QSFP-40G-ER4 40 Gbps QSFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 703I7.1 —
QSFP-40G-ER4 40 Gbps QSFP+ 40km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
WSP-Q40GLR4L 40 Gbps QSFP+ 2km Duplex Fiber SMF LC Optic 10 to 60C Y NX-OS 703I7.1 —
WSP-Q40GLR4L 40 Gbps QSFP+ 2km Duplex Fiber SMF LC Optic 10 to 60C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
QSFP-4SFP10G-CU5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-4SFP10G-CU5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-4SFP10G-CU3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-4SFP10G-CU3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-4SFP10G-CU1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-4SFP10G-CU1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-4X10G-AC7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-4X10G-AC10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-CU5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-CU5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-CU3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-CU3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-CU1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-CU1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-ACU7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-ACU7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-ACU10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-ACU10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-4X10G-AOC1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-4X10G-AOC3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-4X10G-AOC5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-4X10G-AOC7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-4X10G-AOC10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC1M 40 Gbps QSFP+ 1m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-AOC2M 40 Gbps QSFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC2M 40 Gbps QSFP+ 2m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-AOC3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC3M 40 Gbps QSFP+ 3m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-AOC5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC5M 40 Gbps QSFP+ 5m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-AOC7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC7M 40 Gbps QSFP+ 7m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-AOC10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC10M 40 Gbps QSFP+ 10m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-AOC15M 40 Gbps QSFP+ 15m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC15M 40 Gbps QSFP+ 15m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-AOC20M 40 Gbps QSFP+ 20m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC20M 40 Gbps QSFP+ 20m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
GLC-EX-SMD 1 Gbps SFP 40km Duplex Fiber SMF LC Optic -5 to 85C Y NX-OS 703I7.1 —
GLC-EX-SMD 1 Gbps SFP 40km Duplex Fiber SMF LC Optic -5 to 85C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
SFP-GE-T
End Of Sale
SFP-GE-T
End Of Sale
GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y NX-OS 703I7.1 —
GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
GLC-LH-SMD 1 Gbps SFP 550m Duplex Fiber MMF LC Optic -5 to 85C Y NX-OS 703I7.1 —
GLC-LH-SMD 1 Gbps SFP 10km Duplex Fiber SMF LC Optic -5 to 85C Y NX-OS 703I7.1 —
GLC-LH-SMD 1 Gbps SFP 550m Duplex Fiber MMF LC Optic -5 to 85C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
GLC-LH-SMD 1 Gbps SFP 10km Duplex Fiber SMF LC Optic -5 to 85C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
GLC-ZX-SMD 1 Gbps SFP 70km Duplex Fiber SMF LC Optic -5 to 85C Y NX-OS 703I7.1 —
GLC-ZX-SMD 1 Gbps SFP 70km Duplex Fiber SMF LC Optic -5 to 85C Y ACI-N9KDK9-12.2(2) ACI-N9KDK9-13.0(1)
CWDM-SFP-XXXX 1 Gbps SFP 100km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 9.2.1 NX-OS 9.2.1
QSFP-40G-BD-RX 40 Gbps QSFP+ 100m (OM3) Duplex Fiber MMF LC Optic 10 to 70C N NX-OS 703I7.1 —
QSFP-40G-BD-RX 40 Gbps QSFP+ 150m (OM4) Duplex Fiber MMF LC Optic 10 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC25M 40 Gbps QSFP+ 25m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC25M 40 Gbps QSFP+ 25m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
QSFP-H40G-AOC30M 40 Gbps QSFP+ 30m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N NX-OS 703I7.1 —
QSFP-H40G-AOC30M 40 Gbps QSFP+ 30m N/A (Incl AOC and DAC) AOC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP10G-USR 10 Gbps SFP+ 100m Duplex Fiber MMF LC Optic 0 to 70C N NX-OS 703I7.1 —
SFP-H10GB-CU1-5M 10 Gbps SFP+ 1.5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H10GB-CU2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-H10GB-CU2M 10 Gbps SFP+ 2m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N ACI-N9KDK9-12.2(2) —
SFP-H10GB-CU2-5M 10 Gbps SFP+ 2.5m N/A (Incl AOC and DAC) DAC N/A Cable 0 to 70C N NX-OS 703I7.1 —
SFP-10/25G-CSR-S 10/25 Gbps SFP28 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 9.2.1
SFP-10/25G-CSR-S 10/25 Gbps SFP28 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y NX-OS 9.2.1
SFP-10/25G-CSR-S 10/25 Gbps SFP28 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y ACI-N9KDK9-14.0(1) ACI-N9KDK9-14.0(1)
SFP-10/25G-LR-S 10/25 Gbps SFP28 10km Duplex Fiber SMF LC Optic 0 to 70C Y NX-OS 9.2.3 NX-OS 9.2.3
SFP-10/25G-LR-S 10/25 Gbps SFP28 10km Duplex Fiber SMF LC Optic 0 to 70C Y ACI-N9KDK9-14.0(1) ACI-N9KDK9-14.0(1)
DS-SFP-FC8G-SW 8 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 40C N NX-OS 9.2.1 —
DS-SFP-FC16G-SW 16 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 40C N NX-OS 9.2.1 —
DS-SFP-FC32G-SW 32 Gbps SFP+ 190m (OM4) Duplex Fiber MMF LC Optic 0 to 40C N NX-OS 9.2.1 —
Even if it is not listed in the supported list of SFPs, it is working fine at 10G rate. Link is up and active in 10G speed. But I couldnt change the speed to 1G.
You cant change speed on a Fibre port it must be able to negotiate the speed at the SFP itself , no syntax available when a fibre sfp is in the port
You can only change speed on copper port ,If you want 1GB fiber speed use a GLC-SX-MMD for fibre or copper use a GLC-TE speed can be set right down to 10mb
Just because an unsupported SFP worked at 10Gb does not mean it will work at 1GB
One thing you can try is this in global config but it varies on SFP whether it works or not and the fact its working at 10GB may already assume it wont at 1GB
service unsupported-transceiver ----------------Configure support for transceivers not supported by Cisco
any luck with the unsupported command ?
if that doesnt allow it too negotiate speed then you will need a cisco sfp
swaminathan
We are currently using  2 x Cisco 1000BASE-SX SFP Transceiver Module on cisco n9k c93180yc-fx switch. The issue while using this transceiver is the media type is detected as 1G and not 1G/10G. Any suggestions ?
Hello!
The GLC-SX-MM transceiver you are using (which supports the 1000Base-SX standard) only supports 1G speeds, not 10G speeds. As a result, the Nexus is correctly reporting that the media type is 1G-capable and not 10G-capable. This is expected behavior. You can confirm that this transceiver only supports 1G speeds using the Cisco Optics-to-Device Compatibility Matrix tool.
Can you confirm whether the link comes up/up as expected at a speed of 1G in the Nexus?
Thank you!
-Christopher
Hi christopher ,
Thanks for acknowledging. You are right. The 1G link is detected. We tried using Intel and Finisar sfps for 10G port. The media type is detected correctly as 10G. But the Ethernet link is not up(I could not see a green led light to the corresponding port). Any recommended 10G sfps that can be used?
Hello!
A list of supported SFP+ transceivers that support 10Gbps speeds can be found using the Cisco Optics-to-Device Compatibility Matrix tool.
Thank you!
-Christopher
