Cisco NEXUS 93240 drops labeled mpls traffic
ilircisco
Hello
I am using Cisco NEXUS switches only for switching
I have issues with   MPLS labeled traffic passing through NEXUS 93240 . Seems that the switch drop the labeled mulicast traffic .The vpls-xconnect between the PE routers is UP ,but no traffic passing .When try vpls between two PE that are directly connected at  the nexus switches ,the service works OK   (here the mpls traffic is unlabeled --the PHP option)
the version of the swicth is /nxos.9.3.3.bin
The previous 9396 models have worked perfect .No issues passing the mpls traffic
Ilir
6 Replies 6
balaji.bandi
Since you mentioned old nexus model works find, what was the version it was worked ?
May be 9.3 may have bug, do you see any errors or any etheranalyze traffic logs to capture.
suggest to look below guide see any limitations :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/label-switching/b-cisco-nexus-9000-series-nx-os-label-switching-configuration-guide-93x/b-cisco-nexus-9000-series-nx-os-label-switching-configuration-guide-93x_chapter_011.htm...
try debug or capture the logs :
https://community.cisco.com/t5/networking-documents/using-ethanalyzer-on-nexus-platform-for-control-plane-and-data/ta-p/3142665
BB
mkorourke
hi @ilircisco did you ever end up finding a resolution to this in 9.3(x)?
Hello
That version had problems passing the MPLS labeled packets . That caused a lot of problems ,because the switch was for switching the PE routers MPLS traffic and all the L2/L3 mpls circuits were affected.
The version 9.3.9 is OK now
Ilir
Jitendra Kumar
Here is the some steps that can help you.
by default features are disabled hope you have enable it..
Default Settings for MPLS Layer 3 VPNs
Table 1. Default MPLS Layer 3 VPN ParametersParametersDefault
L3VPN feature
Disabled
L3VPN SNMP notifications
Disabled
allowas-in (for a hub-and-spoke topology)
disable-peer-as-check (for a hub-and-spoke topology)
Disabled
Follow below guide..
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/label-switching/b-cisco-nexus-9000-series-nx-os-label-switching-configuration-guide-93x/b-cisco-nexus-9000-series-nx-os-label-switching-configuration-guide-93x_chapter_0101.ht...
Jitendra
Thanks @Jitendra Kumar appreciated. I'll check it out and see if there are any notes or configuration items that may assist.
Re-checking over the bug tracker there seems to be a few bugs relating to NX-OS and MPLS labelled traffic being dropped on transit or pass-through. CSCvr31693 seems to be a good hit for early 9.3(x) releases, I'm preparing a small POC to confirm if it corrects the issue.
Cheers,
Mick
seems you are not on the affected release as your device firmware are 9.3.3 bug has been fixed in this release, its affected 9.3.1. As per the bug details.
Jitendra
