Cisco Nexus C93180YC-FX3 critical sensor fatal conditions
shlomoi
Level 3
Level 3
Hi, since this morning we have been receiving an error message from Nexus to our monitoring system. The show env fan command does not indicate a fault. We must understand whether the problem is with the chassis or the fan.
This is the message:
Hardware Sensor Name : fan.4. Category : fan. Current State : 3 - The sensor is operating under critical or fatal conditions. This may directly affect the functioning of both the sensor and related components
Mark Elsen
  - It's not at all certain that this is an effective problem ; can sometimes be due to snmp bugs , if snmp is used by the tool to check the status of the fans ; checkout the fan module leds ,  which are  located below the air holes on the front of the module.
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
