Cisco Nexus default gateway
Heiko Kelling
Hi Community,
I have another question about Cisco Nexus 5000 switches. This time the problem has to do with the default gateway.
I have configured a layer 2 uplink to a Cisco 3750 on the Nexus:
interface Ethernet1/31
  switchport mode trunk
  switchport trunk native vlan 100
  switchport trunk allowed vlan 100
  speed 1000
These are the vlans:
interface Vlan1
interface Vlan100
  no shutdown
  management
  ip address 139.201.100.250/24
It is possible to ping in the vlan 100 to other switches, but it is not possible to ping to clients in other nets.
In my opinion is the default gateway the problem. In the manuals I found this method to configure a default gateway:
vrf context management
  ip route 0.0.0.0/0 139.201.100.240
vlan 1,100
But it is not working. Can somebody help me.
Thanks in advance!
Reza Sharifi
If the default gateway for vlan 100 is 139.201.100.250 (3750) than you need this on the nexus:
  ip route 0.0.0.0/0 139.201.100.250
vlan 1,100
Also, if you are trying to ping from the nexus, you have to use the vrf name.  For example is you want to ping
139.201.100.250
you need this command ping 139.201.100.250 vrf managment
