Stack switch with etherchannel config
mahesh18
Level 7
Level 7
Hi Everyone,
I have stack of 2 switches 3750.
I config etherchannel between them.
here is result
2      Po2(SD)         LACP      Fa1/0/15(I) Fa2/0/15(I)
Both ports are up up but standalone
Int port channel 2 is down down.
Need to know if this is default behaviour when we config etherchannel between stack switches?
Mahesh
Reza Sharifi
Hi Mahesh,
If the switches are stacked, they are logically one switch.  You can't use portchannel to connect one switch to the other.
You are basically looping ports together.
Reza
Reza Sharifi
Hi Mahesh,
Reza
Hi Reza,
Many thanks for replying back
MAhesh
