Cisco nexus n3k random reboot
bagusprimusindo
hello friends, for the past few months I have had a problem with my cisco nexus n3k where the switch restarts itself, the restart frequency itself can reach 3 or 4 times a week, I have tried "show ver" but the last reset reason is always "unknow"
5 Replies 5
balaji.bandi
We are not sure reason of reboot is this vPC ? standalone switch ?
as per the version of nexus code you running too old.
First step i upgrade to Minimum to 7.0(3)I2(2a)  (latest it 9.3) and see if that fix the issue ?
BB
This standalone switch
i don't know how to upgrade because there is no support, can you share some
legit reference?
Nexus-TIS# dir
2210 Aug 19 00:28:53 2016 .n3k_pre_single_img_upd_config
4096 Aug 19 00:18:47 2016 .patch/
4096 Aug 19 00:36:02 2016 .rpmstore/
76506 Jan 29 08:04:29 2010 20100129_000216_poap_3945_init.log
0 Jan 29 07:15:18 2010 20100129_001518_poap_4067_init.log
0 Jan 29 07:18:46 2010 20100129_001846_poap_3964_init.log
362850 Jan 29 11:55:58 2010 20100129_070216_poap_3908_init.log
0 Apr 27 22:52:01 2020 20200427_155201_poap_4007_init.log
640 Jan 10 13:03:00 2012 license_FOC1549R0YD_11.lic
4096 Aug 19 02:56:35 2016 logflash/
25406464 Jan 10 12:56:42 2012 n3000-uk9-kickstart.5.0.3.U1.2.bin
37857280 Aug 18 22:20:34 2016 n3000-uk9-kickstart.6.0.2.U6.6.bin
114236453 Jan 10 12:57:28 2012 n3000-uk9.5.0.3.U1.2.bin
206973712 Aug 18 22:46:14 2016 n3000-uk9.6.0.2.U6.6.bin
696987648 Aug 18 22:01:30 2016 nxos.7.0.3.I4.2.bin
1024 Apr 27 22:42:44 2020 sprom_2_0_1
1024 Apr 27 22:42:44 2020 sprom_3_0_0
1024 Aug 19 00:18:30 2016 sprom_cstruct_2_0_0
1024 Aug 19 00:19:05 2016 sprom_cstruct_3_0_0
4096 May 30 15:42:58 2022 usbflash0:/
4096 Jan 29 13:00:02 2010 vdc_2/
4096 Jan 29 13:00:02 2010 vdc_3/
4096 Jan 29 13:00:02 2010 vdc_4/
4096 Aug 19 00:18:47 2016 virtual-instance/
1048 Feb 24 17:24:40 2023 vlan.dat
marce1000
 - Upgrade to latest advisory release and check if that can helphttps://software.cisco.com/download/home/283815894/type/282088129/release/9.3(10)
 M.
