Cisco Nexus problem
Heiko Kelling
Hi all,
I try to connect 2 Nexus 5000 switches with 4 Nexus 2000 fabric extender, with this configuration:
feature telnet
cfs eth distribute
feature interface-vlan
feature lacp
feature vpc
feature lldp
feature fex
username admin password 5 $1$dUjUSex4$P8UFSkGpBHs5UFXyv64uj0  role network-admin
no password strength-check
banner motd #Nexus 5000 Switch
ip domain-lookup
class-map type qos class-fcoe
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
fex 101
  pinning max-links 1
  description "FEX101"
  type N2232P
fex 102
  pinning max-links 1
  description "FEX102"
  type N2232P
fex 103
  pinning max-links 1
  description "FEX103"
  type N2232P
fex 104
  pinning max-links 1
  description "FEX104"
  type N2232P
slot 101
  provision model N2K-C2232P
slot 102
slot 103
slot 104
snmp-server user admin network-admin auth md5 0x7e89dcf3cd9ffca751e0e54996ceb845
priv 0x7e89dcf3cd9ffca751e0e54996ceb845 localizedkey
vrf context management
vlan 1
spanning-tree mode mst
spanning-tree pathcost method long
spanning-tree mst configuration
  name dc1
  revision 3
  instance 1 vlan 1-4093
vpc domain 1
  role priority 110
  peer-keepalive destination 192.168.0.2 source 192.168.0.1 interval 500 timeout 3
port-profile default max-ports 512
interface Vlan1
interface port-channel10
  description 5k1-to-5k2
  switchport mode trunk
  spanning-tree port type network
  speed 10000
  vpc peer-link
interface port-channel101
  switchport mode fex-fabric
  fex associate 101
  vpc 101
interface port-channel102
  fex associate 102
  vpc 102
interface port-channel103
  fex associate 103
  vpc 103
interface port-channel104
  fex associate 104
  vpc 104
interface Ethernet1/1
  fex associate 101
  channel-group 101
interface Ethernet1/2
  fex associate 101
  channel-group 101
interface Ethernet1/3
  fex associate 102
  channel-group 102
interface Ethernet1/4
  fex associate 102
  channel-group 102
interface Ethernet1/5
  fex associate 103
  channel-group 103
interface Ethernet1/6
  fex associate 103
  channel-group 103
interface Ethernet1/7
  fex associate 104
  channel-group 104
interface Ethernet1/8
  fex associate 104
  channel-group 104
interface Ethernet1/9
  channel-group 10
interface Ethernet1/10
  channel-group 10
When I connect the fabric extenders with the Nexus 5000 I get the following errors and the fabric extenders are booting:
2009 Feb 26 12:54:03 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX101-2-SATCTRL: FEX-101 Module 1: Cold boot
2009 Feb 26 12:54:19 Nexus5000-h60 %$ VDC-1 %$ %PFMA-2-FEX_STATUS: Fex 101 is online
2009 Feb 26 12:53:59 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX101-2-SOHMS_DIAG_ERROR: FEX-101 System minor alarm on power supply 1: failed
2009 Feb 26 12:54:19 Nexus5000-h60 %$ VDC-1 %$ %NOHMS-2-NOHMS_ENV_FEX_ONLINE: FEX-101 On-line
2009 Feb 26 12:54:32 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX101-2-SOHMS_DIAG_ERROR: FEX-101 Module 1: Runtime diag detected major event: Voltage failure on power supply: 1
2009 Feb 26 12:54:32 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX101-2-SOHMS_DIAG_ERROR: FEX-101 System minor alarm on power supply 1: failed
2009 Feb 26 12:54:46 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX101-2-SOHMS_ENV_ERROR: FEX-101 Module 1: Check environment alarms.
2009 Feb 26 12:54:20 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX103-2-SATCTRL: FEX-103 Module 1: Cold boot
2009 Feb 26 12:54:37 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX103-2-SOHMS_DIAG_ERROR: FEX-103 System minor alarm on power supply 1: failed
2009 Feb 26 12:54:58 Nexus5000-h60 %$ VDC-1 %$ %PFMA-2-FEX_STATUS: Fex 103 is online
2009 Feb 26 12:54:58 Nexus5000-h60 %$ VDC-1 %$ %NOHMS-2-NOHMS_ENV_FEX_ONLINE: FEX-103 On-line
2009 Feb 26 12:55:08 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX103-2-SOHMS_DIAG_ERROR: FEX-103 Module 1: Runtime diag detected major event: Voltage failure on power supply: 1
2009 Feb 26 12:55:08 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX103-2-SOHMS_DIAG_ERROR: FEX-103 System minor alarm on power supply 1: failed
2009 Feb 26 12:55:24 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX103-2-SOHMS_ENV_ERROR: FEX-103 Module 1: Check environment alarms.
2009 Feb 26 12:53:43 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX104-2-SATCTRL: FEX-104 Module 1: Cold boot
2009 Feb 26 12:53:56 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX104-2-SOHMS_DIAG_ERROR: FEX-104 System minor alarm on power supply 1: failed
2009 Feb 26 12:54:12 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX104-2-SOHMS_DIAG_ERROR: FEX-104 Module 1: Runtime diag detected major event: Voltage failure on power supply: 1
2009 Feb 26 12:54:12 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX104-2-SOHMS_DIAG_ERROR: FEX-104 System minor alarm on power supply 1: failed
2009 Feb 26 12:55:06 Nexus5000-h60 %$ VDC-1 %$ %SATCTRL-FEX104-2-SOHMS_ENV_ERROR: FEX-104 Module 1: Check environment alarms.
2009 Feb 26 12:55:29 Nexus5000-h60 %$ VDC-1 %$ %PFMA-2-FEX_STATUS: Fex 104 is online
2009 Feb 26 12:55:29 Nexus5000-h60 %$ VDC-1 %$ %NOHMS-2-NOHMS_ENV_FEX_ONLINE: FEX-104 On-line
All fabric extenders are affiliated on only 1 power supply.
Does anybody know if this is normal, a bug or something with the config is wrong?
Reza Sharifi
Are the FEXs on line?
What is the output of "sh fex"?
