05-12-2017 12:53 AM - edited 03-08-2019 10:32 AM
What is the equivalent feature to the stacking when it comes to Cisco Nexus? Is it VPC?
Solved! Go to Solution.
05-12-2017 02:33 AM
stacking is not supported on nexus switches at all
if you want to know what a 9k is capable of check the data sheet , each model is different in what they can do they range in throughputs features etc depending on the model you chose
here is the link to compare the 9k models , you can see what each type os capable of
http://www.cisco.com/c/en/us/products/switches/nexus-9000-series-switches/models-comparison.html
usually the design is only 2 nexus per vpc design like screenshot but you could interlink vpc domains but I have never done it we follow standard practices , not sure why you would need more than 2 , multiple linecards and resiliency involved in 2 chassis
05-12-2017 02:20 AM
Sort of yes nexus ha is VPC feature , you build a VPC domain between the 7ks or 5ks with fexes connected that are linked to both 5ks/7ks with a crossbar between them , the 5ks / 7ks then act as one logical unit like stacking switches but its a different type of feature
05-12-2017 02:26 AM
Hi Mark,
So when it comes to Nexus 9k.
Is it possible to bundle more than 2 devices into same vpc domain?
What is the bandwidth?
port count in VPC?
Does Stacking is only for catalyst series? Is it not supported in nexus right?
05-12-2017 02:33 AM
